XML Mapfiles... are we looking to far?
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Wed Jul 19 14:27:49 EDT 2006
Sounds like this would be a worthwhile discussion in Lausanne :)
> -----Original Message-----
> From: UMN MapServer Developers List
> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Julien, Heryk
> Sent: Wednesday, July 19, 2006 2:04 PM
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-DEV] XML Mapfiles... are we
> looking to far?
> Hi,
> I made a first try at creating an xml mapfile schema (xsd)
> this morning. It's not finished yet but the general idea is
> there... I just wanted to have your comments before pushing
> on. I used the same element names as in the text mapfile.
> This will permit us to write a stylesheet (xsl) that loops
> loop thru the xml file and reuses the element names in the
> mapfile text output format... this way the xsl will be easy
> to maintain in future xsd versions.
> I have to point out that I do not know all of Mapserver's
> mapfile elements so I just went thru the map and layer
> reference documentation to write the xsd. I usually work with
> only the basic mapfile tags needed to create wms and wfs services.
> (The xsd is attached to this email. Is there a special way to
> send an attached file to the dev group mailing list?)
> Héryk
> -----Message d'origine-----
> De : Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
> Envoyé : 19 juillet 2006 10:51
> À : MAPSERVER-DEV at LISTS.UMN.EDU; Julien, Heryk
> Objet : Re: [UMN_MAPSERVER-DEV] XML Mapfiles... are we looking to far?
> I've thought for sometime that using XSL might be a nice
> bridge as we move in that direction. At least one could
> manage their configuration in XML than transform as necessary
> to create a mapfile for run-time use. There were some folks
> comtemplating developing a configuration schema file as a
> start a while back but they've disappeared as far as I know.
> I think that would be a nice first step if someone were to
> take it on: create mapfile XSD and XSL files. Ultimately we
> probably will have to be able to read a XML config file. I've
> toyed with using expat in developing a mapfile_xml.c. The
> underlying C structures would be the same, but a SAX parser
> would be used instead of Flex to tokenize the config file.
> Just never had time.
> Steve
> >>> "Julien, Heryk" <hjulien at NRCAN.GC.CA> 7/18/2006 8:45 AM >>>
> Hi Tamas,
> I think there are many advantages in using xml. First, XML
> files are easy to create and schema validation can check
> document structure while you are writing it. Schema aware
> editors can also give you hints and do automatic inputs of
> required tags while writing mapfile document. Yes Mapserver
> validates mapfiles, but I think the addition of a mapfile
> structure validator like xsd would facilitate mapfile
> creation and debugging.
> Schemas can help newbie's to create there first config files
> and advanced users and developers visualise, communicate and
> work on the current mapfile format. I also think that it
> would be easier to extend the mapfile structure in future
> Mapserver versions if we where using an xml format... for
> example adding new OGC tags to mapfiles would be very easy.
> Plus with all the new xml editing tools out there, schema
> creation, visualisation and validation has become a child's
> play (hmmm.... well almost!).
> Just as you said earlier, automating map config creation
> would be another great benefit. And if Mapserver could read
> non static mapfiles (via URL's), xml would be a great way to
> create dynamically generated mapfiles. If we consider
> mapfiles as being a kind of database (or database pointer),
> wouldn't it be great to be able to easily process it on the
> fly? XML coupled with xsl, xpath and databases would be one
> great way to do that kind of manipulation. A little like OGC
> WMC layers that are pointing to different data layers (wms
> layers), we could have dynamically generated mapfiles instead
> of one huge static file containing all data layers.
> Xml being rapidly more and more widespread, ways for
> developers to input serialization data into Mapserver would
> be much greater and flexible. Mapfile management would be
> more open and greatly enhanced with the use of xml. For
> example a url fetched xml mapfile would enable us to easily
> modify a mapfile service according to certain parameter like
> language. We could thus have an automated multilingual
> mapfile. Currently we have to save a static mapfile for every
> language. They all point to the same data but containing
> language specific titles and metadata.
> Being an OGC fan, I think there decision to use xml to
> disseminate data and ease interop has been a good choice. In
> that same line of thought, I think an xml mapfiles format to
> serialize Mapserver would be a logical next step.
> Cheers
> Héryk
> _____________________________
> Héryk Julien
> Research Officer
> Natural Resources Canada
> 490 rue de la Couronne
> Québec, Canada
