Pre-RFC,
pulling rendering/labeling parameters from attributes...
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Jun 6 23:54:56 EDT 2006
Couple of comments:
- TEXT expressions are already supported (e.g. TEXT "[address] [st] [dir]). I have thought about extending those to allow text operations like commify, substr, toupper, tolower and so on. That would require a second parser (bison grammar) I believe, but is doable.
- one way global sustitution could be accomplished by slurping a mapfile into a big string buffer and doing substitution there, then tokenize the buffer. I had that working several years ago but never really pursued it.
- I don't see much value in expressions for angles and that's about the only place it makes sense so why bother. (my 2 cents anyway)
I guess it makes sense to craft an RFC to hold these ideas...
Steve
>>> Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 06/06/06 8:55 PM >>>
Frank Warmerdam wrote:
> Stephen Woodbridge wrote:
>> Ok, glad I read this one before posting the exact same thing! only I
>> would have done my example like:
>> SIZE [sizeattribute]
>> ANGLE ([angleattribute] - 90.0)
>> LABEL
>> TEXT ("Label: " . [labelattribute] . ".")
>> END
>> This would require a lot of changes, but could be fully backwards
>> compatible.
> SteveW,
> I assume part of the benefit here is that we can use the same substitution
> engine used for expressions? (and I guess actually evaluating in the
> expressions in the ANGLE case above).
> I certainly like this degree of generality, though internally I would like
> to see a fixed value and possibly a simple variable substitution handled
> via some sort of short cut to reduce the amount of expression processing
> for
> each feature. I would hate to have ANGLE 0 result in a full expression
> parse
> and evaluation for each feature.
> Best regards,
Frank,
I like the generalization, but I agree in the need for not using the
expression evaluation if you don't need to. For example:
ANGLE 0
ANGLE [angleattribute]
Would not need expression evaluation, but any clause starting with "("
would be assumed to be an expression. I could live without the
expressions but I think they are handy for a lot of simple or low volume
sites.
I guess what I would like to see is a generalized attribute substitution
for any single value that can be placed in a layer definition. This
would imply that you would need three columns for COLOR [R] [G] [B],
although it might be made smart enough to recognize COLOR
[colorattribute] as a string and parse it.
Steve have you given any thought into URL parameter substitution and how
it might or might not play with this. For example:
ANGLE %angle%
ANGLE [%angleattribute%]
So all values can be either:
constant
%parameter%
[attribute]
[%parameter%]
(expression)
where expression may/may not contain any of the items above. OK, this is
getting into the grand unification theory of variable substitution :)
-Steve
