RFC 19: style and label attribute binding...
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Thu Jun 8 13:43:15 EDT 2006
Steve,
So how does this work for labelitem? Do we use the TEXT 'myLabelItem'
syntax? and how is that different from TEXT 'myLabelText'? In general, I
would think we would want a clear syntactic identifier that indicates I
am passing a binding vs a literal string vs a constant vs a URL parameter.
Have you given any thought into using this to also bind to URL
parameters? Does this break any of the existing URL parameter substitutions?
-Steve W.
Steve Lime wrote:
>>>> Stephen Woodbridge <woodbri at swoodbridge.com> 6/8/2006 8:52:53 AM >>>
> Steve Lime wrote:
>> Hi all: I put some ideas to paper base on the thread yesterday as RFC
>> 19:
>> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-19
>> The change really isn't that bad, but is probably a 5.0 modification
>> (which could be our next release).
>> Steve
>> Steve,
>> This sounds like a very straight forward implementation that is easily
>> extensible to other attributes. It looks like bindings will only be
>> implemented within the layer/style objects, but not class objects which
>> I assume is because those fields that could be bound are all deprecated
>> and should be in style style.
> Those properties are surrogate for styles anyway so for a mapfile you could
> support:
> CLASS
>   SIZE 'mySizeItem'
> END
> You can't set $class->{size} from MapScript anyway so in that environment
> it's not an issue.
>> Do you have a list of bindings that you plan to implement in this
>> initial implementation? Are there items people might reasonably think
>> should have bindings that you plan to NOT implement for any reason? Like
>> in the CLASS object.
> I'll have to create a list. I had not planned on supporting any of the boolean
> parameters (e.g. ANTIALIAS), but just about everything else would be fair game.
>> Backwards compatibility:
>> I think is a more rhetorical question that needs to be discussed.
>> On the one hand, it seems it would not be difficult to to maintain the
>> existing angleitem, xxxitems fields and mapscript interfaces, but to
>> change them to use the new implementation in addition to adding the new
>> interfaces you describe and thus NOT brake Backwards Compatibility.
> It would not be difficult within a mapfile, but would be difficult, if not impossible,
> within MapScript. Something like $style->{angleitem} can not be translated into
> $style->setBinding(...) without typemaps so it's not worth it.
>> On the other hand, IF we are going to brake Backwards Compatibility,
>> then I think we should clean up a lot of stuff and remove the deprecated
>> items that make the mapfile and mapscript complex because there are
>> multiple places that key words can be used, but the code only works for
>> some new features if you use one of the items and not the other, like
>> anti-aliasing requires you to use the style object and not the class
>> object to define you styling. I think clean up mapscript and the mapfile
>> while painful for some users would have the benefit of a cleaner,
>> smaller, more rational implementation.
> In this particular case I think some breakage is inevitable, but remember these are
> lightly used features so the risks are relatively small.
>> This also raises in my mind the need for a clearly stated feature
>> supported/deprecated/removal policy and an old version support policy. I
>> think we have most of that in that we try to act in consistent manner
>> from release to release and maintain backwards compatibility except on
>> major releases. But we do not seem to have a policy on feature
>> deprecation and obsolescence and removal. This is probably because we
>> rarely if ever remove features.
> I'm all for consistency in point releases but major releases give us the opportunity
> to clean things up a bit. Even in those cases disruption should be minimized. In this
> case I would advocate a clean up...
>> -SteveW
> Steve
