RFC 19: style and label attribute binding...
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Jun 8 16:53:06 EDT 2006
Steve Lime wrote:
>>>> Daniel Morissette <dmorissette at MAPGEARS.COM> 6/8/2006 1:32:29 PM >>>
> Stephen Woodbridge wrote:
>> So how does this work for labelitem? Do we use the TEXT 'myLabelItem'
>> syntax? and how is that different from TEXT 'myLabelText'? In general, I
>> would think we would want a clear syntactic identifier that indicates I
>> am passing a binding vs a literal string vs a constant vs a URL parameter.
>> Have you given any thought into using this to also bind to URL
>> parameters? Does this break any of the existing URL parameter
>> substitutions?
>> I agree that we need a syntactic identifier to indicate that this is an
>> item binding and not a constant.
>> The case of TEXT may be a bit different because it already supports item
>> substitutions using square brackets, but we should define something
>> today so that we don't end up being stuck later when we need to bind
>> string parameters to attributes. Perhaps we could use the square
>> brackets [] to be consistent with expressions and the existing TEXT
>> substitution.
> That could work I guess although I'd probably favor no quotes around the []'s
> so we could return a MS_BINDING or MS_ITEM token (and strip the []'s) from
> the lexer.
We should use the same for the symbols which will make it faster,
because you should not have to do a failed symbol lookup for symbol
attributes and you don't have to worry about an existing symbol
preventing you access to an attribute column.
>> Another comment/question I had with respect to the RFC is how should
>> enumeration value be written in the data files when we use attribute
>> binding.
>> For instance, if I have:
>> POSITION '[myPositionItem]'
>> Then what should the values of myPositionItem be in the data files?
>> integers (101,102,103,...), or strings (UL, LR, UR...)?
> The would contain the string you'd normally see in the mapfile. We'd use the
> lexer to turn them into a appropriate underlying interger, just like the way
> you can change parameters via URL...
so the lexer will evaluate each row?
How will we handle a NULL/invalid value in a column, will/should there
be something like:
POSITION [myPositionItem] exception 'LJT' null 'LJT'
or
POSITIONEXCEPTION 'LJT' NUL 'LJT'
COLOR is also a an interesting problem, do we do:
COLOR [redItem] [greenItem] [blueItem]
or
COLOR [myColorItem]
or both? where myColorItem value would be like "255 255 255"
-SteveW
>> Using enum values as strings may be the safest way to go and would be my
>> preference, but come with a performance price. At least the way plan to
>> handle enums should be documented in the RFC.
> There's no doubt this could get expensive but in general it only makes sense with
> relatively small sets of features anyway.
> The other issue that has not been brought up is legends. With bound values building
> a legend is very difficult if not impossible.
We might want to do a graphic like [A] to indicate styled by attribute.
I can't think of a better idea at the moment.
>> Daniel
>> Daniel Morissette
>> http://www.mapgears.com/
> Steve
