Proposing to support for creating maps with mapserv.exe using
the command line
Frank Warmerdam
warmerdam at POBOX.COM
Wed Jun 21 11:21:03 EDT 2006
Tamas Szekeres wrote:
> Developers,
> I would be required to enable using mapserv.exe as a commandline tool
> for the map image creation. The current implementation already has a
> QUERY_STRING argument to receive the cgi style parameter list.
> However mapserv.exe is creating the generated image onto the stdout
> including the content type header information. With the following
> patch one could specify the output file as an additional commandline
> parameter, like:
Tamas,
I would be inclined to approach this as a flag to suppress the
content type flag, and to leave it to normal file redirection to
write to a file. But if you are doing this, wouldn't it also be
desirable to have it work for WMS and other sorts of requests too,
not just "traditional mode" mapserver map rendering? If so, I think
you would need to touch quite a few additional bits of code.
I would add that the shp2img utility can be used for commandline
map output though it lacks some options available with mapserv.
Best regards,
> In order to achieve this functionality the following changes should be made
> --- mapserv.c 14 Dec 2005 19:55:07 -0000 1.150
> +++ mapserv.c 21 Jun 2006 14:50:07 -0000
> @@ -1109,6 +1109,7 @@
> char buffer[1024];
> imageObj *img=NULL;
> int status;
> + char* outfile = NULL;
> /* Process arguments. In normal use as a cgi-bin there are no */
> @@ -1147,6 +1148,9 @@
> putenv( "REQUEST_METHOD=GET" );
> putenv( argv[1] );
> + else if(strncmp(argv[iArg], "-o", 2) == 0) {
> + outfile = argv[iArg] + 2;
> else
> /* we don't produce a usage message as some web servers pass
> @@ -1318,9 +1322,9 @@
> msIO_printf("Content-type:
> %s%c%c",MS_IMAGE_MIME_TYPE(msObj->Map->outputformat), 10,10);
> if( msObj->Mode == MAP )
> - status = msSaveImage(msObj->Map,img, NULL);
> + status = msSaveImage(msObj->Map,img, outfile);
> else
> - status = msSaveImage(NULL,img, NULL);
> + status = msSaveImage(NULL,img, outfile);
> if(status != MS_SUCCESS) writeError();
> @@ -1344,7 +1348,7 @@
> if(!img) writeError();
> - status = msSaveImage(NULL, img, NULL);
> + status = msSaveImage(NULL, img, outfile);
> msFreeImage(img);
> @@ -1579,7 +1583,7 @@
> - status = msSaveImage(msObj->Map, img, NULL);
> + status = msSaveImage(msObj->Map, img, outfile);
> msFreeImage(img);
> Any objections?
> Best Regards,
> Tamas
and watch the world go round - Rush | President OSGF, http://osgeo.org
