ArcSDE 9.1 Support
Dave McCann
mccann.dave at GMAIL.COM
Thu Jun 22 12:04:45 EDT 2006
Got it working now.
It appears to be the version of MS4W we were using. We switched from version
1.5.4 to version 1.5.3 after getting some great advice via mapserv IRC
channel and now it's working fine.
If we need to add the query by polygon capability for sde would anyone be
interested in writing the code?
Thanks for the assistance.
-----Original Message-----
Sent: Wednesday, June 21, 2006 1:16 PM
To: Dave McCann; MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] ArcSDE 9.1 Support
At 11:30 AM 6/21/2006, Dave McCann wrote:
>We're looking into implementing mapserver in a production
>environment utilizing SDE connections to map data.
>I was looking at the current docs on SDE and saw that spatial
>selects are currently only supported by queryByAttributes and queryByRect.
>Is there any activity for developing a queryByPoly (select based on
>spatial area of a polygon)?
>We've considered using Tomcat to poke into SDE for the spatial
>select as a workaround but would prefer to use any existing
>functionality in mapserver.
>I've been trying to conduct some local testing of performance with
>SDE layers but have been unsuccessful with a simple single layer
>request. Can anyone point me to a thread or any documentation that I
>can use in troubleshooting our current mapserver config (MS4W) with SDE?
There have been folks having success with the MS4W 1.5.3 binaries and
SDE 9.1. You might catch me on IRC to hammer out specific issues,
but I think the MS4W docs explain how to swap the dlls. Only other
issue should be making sure the SDE SDK binaries are on your PATH and
if you're using IIS that the SDE dlls have the execute bits set for
the internet user. Use mapserv.exe -v on the command line to confirm
that SDE support is enabled.
Implementing support to allow MapServer SDE to do queryByPoly should
be pretty straightforward, but I haven't found time, funding, or need
to implement it. I don't know if Steve has found a need for it
either (I think he uses the SDE stuff pretty regularly
also). Patches always welcomed ;)
Howard
