GEOS Support
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Jun 27 11:57:19 EDT 2006
Hi all: I did commit the port of the C++ support for GEOS to the new C-API. Seems to work well in testing. I wrapped all the meaningful GEOS methods:
- buffer, intersection, union, difference, symDifference, boundary, getCentroid, convexHull
- contains, within, overlaps, intersects, disjoint, equals, touches, crosses
- area, length, distance
and have included those in the SWIG binding for shapeObj's.
To do's or gotchas:
- configure needs to detect a minimum version of GEOS (2.2.2 or higher - that's when length and area were exposed to C API)
- need to handle z coordinates if enabled in MapServer
- error handling ain't great, it's not as easy to get at GEOS errors as before. We could define a GEOS error handler and register it when initializing
the library but I worry about conflicts with PostGIS or OGR that also use it.
- there's one MapScript issue. There already is a contains method that takes a pointObj. I created an overloaded method for contains that takes
a shapeObj. In perl that's ok, but I'm not sure about other languages.
- PHP/MapScript needs to be updated.
I'll update all necessary bugs in Bugzilla with details. Let me know if you run into issues beside the one already fixed...
Steve
