Perl mapscript memory leak?
Daniel Morissette dmorissette at MAPGEARS.COM
Wed Jun 28 11:22:53 EDT 2006
FYI I fixed a leak of shapefile handles that affected ka-Map
installations and could likely be the source of (some of) your leaks.
Perhaps try again after making sure you have that fix, it's in both 4.9
and 4.8.x:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1802
Daniel
Stephen Woodbridge wrote:
> Hi Steve et al,
> I ported the ka-map precache2.php to perl and it seems to have a memory
> leak. I'm not sure what is leaking but when I running it, like on the
> 1000000, and watch top, you can see the memory grow and it eventually
> fails to on $oMap->draw() command. If I rerun the script and skip the
> already generated tiles, it gets to that same image and works fine then
> memory grows as it writes more tiles and dies again.
> Processing scale=1000000, cellSize=0.00317478168804209
>   geo dimensions: -160, 15 : -60, 75
>   pix dimensions: -50397.16608, 4724.73432 : -18898.93728, 23623.6716
>   meta dimensions: -51200, -24320 : -17920, -3840
>   meta tiles: 26 x 16 = 416 meta tiles and 10400 tiles
>     Group: __base__
> Can't call method "save" on an undefined value at ./precache.pl line 352.
> There is a chance that this is GD.pm related, but I'm guessing it is
> more likely a problem with perl/mapscript. Neither GD.pm nor mapscript
> have explicit image destroy methods. These are all in narrow scoped
> loops and I have try to explicitly undef the variables but that doesn't
> help.
> I'm running a version of mapserver cvs from a few weeks ago. I can
> upgrade to the current cvs, but was reluctant to in the middle of SteveL
> doing GEOS commits yesterday.
> This would be a good stress test of the API and I'm willing to provide
> the script.
> Any thoughts?
> -Steve
Daniel Morissette
http://www.mapgears.com/
