Contributor list...
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Mar 7 23:28:42 EST 2006
Attached is a list based on some searches of the list archives, CVS password files, and source greps. I appologize if I've missed anyone, but it is certainly possible. There is a lot of code and many years to cover. This is only contribution through code. Please pass along edits...
Attached as CSV and Excel files...
Steve
>>> Steve Lime <steve.lime at DNR.STATE.MN.US> 03/06/06 10:16 AM >>>
Hi all: As part of the OSGF incubator process we will need to deal with contributor agreements for both new
and past contributors to MapServer. I'd like to start compiling a list of folks that have added significant (more
than simple bug fixes) bits of code. I'll post a list based on who has CVS access later today or tonite to kick
things off, but would ask you all to think about who you've worked with that might not be widely known.
For example, Pete Olson with the State of Minnesota contributed the EPPL7 and much of original raster
code but is not widely known. I'm sure there are others.
Other thoughts:
1) How should an organization like DMSG be handled? Should an organization sign an agreement like this
or should individual developers? (there are proposed agreements for both cases)
2) Should I have to sign 3 agreements, one for each organization I have contributed code under? (UMN,
DNR, and as myself)
3) What exactly is the definition of "significant bits of code"?
You can read the draft agreements on the OSGEO wiki: http://www.fossgis.de/osgeo/index.php/Contributor_Agreement
Steve
Name: MapServer Contributors.xls
Type: application/octet-stream
Desc: Excel 97
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20060307/53c0098c/MapServerContributors.obj
Name: MapServer Contributors.csv
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20060307/53c0098c/MapServerContributors-0001.obj
