maplexer.c and new CONNECTIONTYPE value
Robert Hollingsworth
reh2 at PRODIGY.NET
Thu Mar 9 01:09:39 EST 2006
Hello,
I'm developing on WinXP in the MS4.6.2 code base, adding a new input source
type, such that the switches in maplayer.c will include my new "MS_XXX" and
launch into msXXXLayer functions that I'm developing.
I want the Mapfile LAYER.CONNECTIONTYPE to accept a new value "XXX" and
toward that end I have:
map.h: added to MS_CONNECTION_TYPE enum MS_XXX
mapfile.c: in loadLayer() case CONNECTIONTYPE added MS_XXX as arg to
getSymbol(), but I notice that's all wrapped up in msxxlex(), so...
I've seen maplexer.l, which I understand to be fuel for the flex program,
and running flex on that will give me maplexer.c, but the evidence I've seen
suggests that flex doesn't run on windows.
Must I somehow get maplexer.c altered to show something similar to
case 238:
YY_RULE_SETUP
#line 349 "maplexer.l"
{ return(MS_WMS); }
YY_BREAK
in order to get the rest of the things I've done to work right? Or is it
much more complicated than that? Or can I leave maplexer.c completely alone?
thanks,
REH
