MapServer 4.8.2
Hallgren Johan E jhhal at WMDATA.COM
Fri Mar 10 02:11:55 EST 2006
Hi
I have to ask you folks.
I saw two weakness with MapServer/MapScript related to ArcSDE and Oracle
Spatial. There was when querying layers with attribute queries, with and
without geometries. Is I understand it the ArcSDE one was addressed, but
what happened with the other one with OracleSpatial. Will that one also
be solved in the planned release?
/Johan
___________________________________
Johan Hallgren
WM-data
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-844 65 (int: +46-2384465)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
http://www.wmdata.se
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
On Behalf Of Howard Butler
Sent: den 10 mars 2006 06:20
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-DEV] MapServer 4.8.2
Let's release this baby.  I propose we do it Wednesday, March 15th.
Some open bugs that might need some attention:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1705 - Symbol
rotation leaks memory
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1684 - Pixmap SIZE
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1699 - Point
Queries in SDE throws an error
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1702 - Shapefile
handles getting left open in the case of bad data
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1700 - OGR
tileindex sources always opened as shapefiles
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1683 - configure.in
should be able to detect the Oracle "instant client" rpm distro
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1669 - msSaveMap()
should write out TRANSPARENCY ALPHA
There may be many others ;)  Let's clean them up and get this out the
door.
Howard
