Databases and MapServer
Hallgren Johan E
jhhal at WMDATA.COM
Wed Mar 15 02:15:17 EST 2006
That's OK for me.
I think I'm responsible for driving the issue off the dev-list. The
reason was that when I started I wasn't sure if my questions were silly
or relevant.
Just let me know if you have any questions or need feedback.
Best Regards
Johan
___________________________________
Johan Hallgren
WM-data
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-844 65 (int: +46-2384465)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
http://www.wmdata.se
-----Original Message-----
Sent: den 14 mars 2006 19:31
To: Hallgren Johan E
Cc: Howard Butler; Steve Lime; dmorissette at dmsolutions.ca;
warmerdam at pobox.com
Subject: Re: [UMN_MAPSERVER-DEV] Databases and MapServer
Hi all,
Hallgren, I intend to add this feature, like Howard did in SDE
driver, but I can't do this week because I'm not in the lab. I just go
back next Monday.
Using what Daniel wrote I believe that we need to start a discussion
to improve the query methods in Mapserver, because not only the Oracle
Spatial is affected, but PostGIS, SDE, MySQL too. Maybe a new feature
for 5.0 release, query methods specific for spatial databases.
Can we pass this discussion to -dev list again?
Best regards.
Fernando Simon
Hallgren Johan E wrote:
> Hello Howard,
> Yes it could work but I haven't tried it. There are two things I
bother
> on that are important for me, and the first is the possibility to do
> more complex queries.
> I can ask it again; is it possible (for example) to do a spatial query
> with a polygon and a buffer, and optionally combine that with an
> attribute query? I will just ensure that mapserver supports different
> options of queries supported by the specific database used. Or at
least,
> that mapserver have an architecture that can be extended without
rebuild
> everything.
> And the other ting is that this should be supported by OracleSpatial
> also (I haven't seen any conversation related to that option).
> Regards
> Johan
> Johan Hallgren
> WM-data
> Pelle Bergs backe 3
> From: Howard Butler [mailto:hobu at iastate.edu]
> Sent: den 13 mars 2006 17:20
> To: Hallgren Johan E; Steve Lime; fsimon at univali.br
> Cc: dmorissette at dmsolutions.ca; warmerdam at pobox.com
> Subject: RE: [UMN_MAPSERVER-DEV] Databases and MapServer
> Johan,
> Is something like this going to be sufficient?
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1708
> It has been added to CVS HEAD if you want to try it out.
> Howard
> At 02:32 AM 3/13/2006, Hallgren Johan E wrote:
>> I will try to explain.
>> I have tried a database approach for storing spatial data and display
>> with mapserver. The layer had about a million polygon features.
>> Displaying those was not a problem but when I should do a spatial
query
>> there was really bad performance. In my case, I saw that the query
>> direct in the database was much faster so I tried to find out what
the
>> difference was, what I saw was.
>> In my query I did not care about the extent, I just want to query a
>> single row/id. In MapServer the extent was always added so a query on
a
>> single row combined with an extent added a lot to the retrieval time.
I
>> tried to find out a way to se if the extent was the same as the
>> layer-extent and in that case, skip the spatial part of the extent.
It
>> would be better if the extent could have a null value and in that
case
>> skip it. I also saw a need to manage other spatial operators, like
>> polygons. My image was that both Oracle Spatial and SDE had a lot of
>> possibilities but way few of these was available at thru mapserver.
>> Does it make thing clearer?
>> Regards
>> Johan
>> Johan Hallgren
>> WM-data
>> Pelle Bergs backe 3
>> Sent: den 10 mars 2006 20:12
>> I'm confused. What is it we were trying to do here again? Just
>> check for a null extent and not attempt to query with the layer's
>> extent if we were doing spatial queries?
>> At 03:02 PM 3/2/2006, Hallgren Johan E wrote:
>>> Yes, you are right. I saw it solely from my perspective but you have
>>> better knowledge over the MapServer and the architecture. To
> continue,
>>> how could these improvements be achieved? Could a new set of
> arguments
>>> be added to the function quite soon, and the actual implementation
be
> a
>>> "longer term" work? Or could I expect that it suddenly works as I
>> wish:)
>>> I'm not the right person to say if a single stage query mechanism or
>>> two-stage ditto is best, but I can say that for me a single query is
>>> more logical. From my C# perspective I don't see how two stage
> queries
>>> should look like with resultCacheMemberObj and so on, but maybe
> that's
>>> just lack of knowledge.
>>> I'm interested in how this will "go on".
>>> Best Regards
>>> Johan
>>> Johan Hallgren
>>> WM-data
>>> Pelle Bergs backe 3
>>> From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
>>> Sent: den 1 mars 2006 23:22
>>> To: fsimon at univali.br
>>> Cc: dmorissette at dmsolutions.ca; hobu at hobu.net; warmerdam at pobox.com;
>>> Hallgren Johan E
>>> I don't think the fact that msWhichShapes is used for drawing and in
>>> query functions is bad. Quite the contrary, the fact the same
> function
>>> is used for query and drawing is a good since they do the same
thing-
>>> identify candidate features for further processing. (FILTERs in the
>>> mapfile are nothing more than attribute queries) I do think the
> drivers
>>> just need to get better at optimizing what is passed off to the
>> database
>>> and ignoring the spatial filter in certain instances is one of those
>>> optimizations. Shapefiles already do this I believe.
>>> The two-stage query mechanism is another problem altogether. One
>>> potential idea is to extend msLayerWhichShapes (or add other similar
>>> functions) to deal with more complex filters such as feature
>>> intersections. That way msLayerWhichShapes (really the driver
> specific
>>> version) would set things up so that repeated calls to msNextShape
>> could
>>> be used to retrieve features just once. (msLayerGetShape would go
> away
>>> in this case)
>>> It get's complicated though since executing a query and actually
>>> processing the result set are not done one right after another. Plus
>> add
>>> feature post classification with classObj expressions, feature
> queries
>>> (features from one layer used to query others) and so on. Two stages
>>> hurt performance but are *very* flexible in what you can do.
>>> Steve
>>>>>> Fernando Simon <fsimon at univali.br> 03/01/06 3:03 PM >>>
>>> Hi folks,
>>> I go back from a holiday just this afternoon. I'm reading my
>>> e-mails since last Friday just now, sorry for the delay.
>>> For Mapserver I believe that the problem is because the same
>>> functions are used for query and draw modes. The Mapserver core call
>> the
>>> same function to retrieve tabular and spatial data. And the problem
>> that
>>> Johan report occur in this moment.
>>> In maporaclespatial.c I used the SDO_FILTER operator to
> restrict
>>> the data in the query, so the spatial data that Mapserver reads is
> the
>>> data that are inside of the map extents. But when a query is
executed
>>> this function is executed too. In my opinion, we can pass a flag or
>> pass
>>> null for the extents(rect) in query modes to fix it, and after we
> just
>>> need to change a little the data drivers (Oracle, SDE, PostGIS,
> Shape,
>>> OGR) to check for null extents and don't use it in the query's.
> Another
>>> way is create separate functions for query and draw methods.
>>> Another point that I want to report is a issue with the query
>>> methods, I spoke with Daniel when he come here last year in the User
>>> Meeting, did you remember Daniel? When a query is executed the
>> Mapserver
>>> call a function to query the data and call another function to
> retrieve
>>> the tabular data for all returned records. And for every call to
this
>>> function Mapserver needs to reconnect in the data source. Daniel do
> you
>>> have more ideas about this point?
>>> Johan, did you change the maporaclespatial.c? Can you send me
>> your
>>> changes?
>>> Best regards.
>>> Fernando Simon
>>> Steve Lime wrote:
>>>> Howard and I are talking off-list about SDE specifically. This is
>> not
>>> just a query issue, but a drawing one as well. Often you can be
> zoomed
>>> out well beyond the extents of a layer and in that case it doesn't
> make
>>> sense to apply a spatial constraint at all since the selection
>>> rect/layer rect overlap test suffices. I'm pretty sure the shapefile
>>> code works this way and just uses the FILTER (which is all an
> attribute
>>> query is) if present. Otherwise all features are returned. The same
>>> logic should work with SDE, Oracle Spatial and everything else for
> that
>>> matter.
>>>> I've already seen the SDE patch, and the changes for Oracle should
>> be
>>> passed along (to Fernando at a minimum) too.
>>>> I'm now using both SDE and Oracle Spatial at work so that frees up
>>> some time to implement.
>>>> Steve
>>>>>>> Frank Warmerdam <warmerdam at pobox.com> 03/01/06 7:38 AM >>>
>>>>> Hello again,
>>>>> I hope you have got my email from yesterday regarding
> improvements
>> in
>>>>> the attribute query functionality in SDE and OracleSpatial. This
> is
>>>>> improvements I have to deal with if we should continue to work
> with
>>>>> MapServer.
>>>> Johan,
>>>> I skimmed it, but this isn't my area of specialization so I didn't
>>>> comment.
>>>>> Today I have made some changes to OracleSpatial also. I know my
>>> solution
>>>>> isn't optimal but se it as a workaround right now. If you would
>> have
>>> my
>>>>> code, just let me know.
>>>>> I have to mention that what I really would like to have is better
>>>>> functionality for attribute/spatial queries when working with
>>> databases.
>>>>> It could be either spatial or attribute or a combination of these
>> in
>>> a
>>>>> query. For shapefiles its better, but as I can see it, it doesn't
>>> work
>>>>> for databases; the performance is just to poor. As I can see a
>>> function
>>>>> like layerObj.QueryDatabase(string query, geometry shape) would
> be
>>> good.
>>>>> This mapscript-function should be directly mapped to a c-function
>> for
>>>>> respectively database.
>>>>> I would appreciate if you could comment my initiatives, so I know
>> if
>>> my
>>>>> work is valuable.
>>>> I think it is important to be able to issue queries without a
>> spatial
>>>> constraint and the difficulty of doing so currently is a defect of
>>>> MapServer and should be corrected.
>>>> I don't know how best to fix it, and what the implications of such
>>> changes
>>>> might be. But if you are willing to work on it that would seem to
>> be
>>>> useful.
>>>> I do think we need more test suite tests around this area before
> we
>>> change
>>>> too much. To the best of my knowledge there are no automated
> tests
>>> that
>>>> address attribute queries, but I could be wrong.
>>>> If changes to how queries are done need to be address in the
> raster
>>> query
>>>> or mapogr.cpp, I would be willing to help out. I'm pretty afraid
> of
>>>> the SDE, Oracle and PostGIS code though.
>>>> Best regards,
