Problem with fastcgi
Clint Johnson
cjohnson at REFRACTIONS.NET
Fri Mar 17 14:14:12 EST 2006
[Preamble]
*Version*: Mapserver 4.6.2
*Platform*: Windows
*Web server*: Apache 2.x
Hi guys,
I'm having a problem getting a self-compiled mapserver to run in fastcgi
mode; however, it works fine in regular cgi mode. Behold some apache
error log entries:
**Start**
[Fri Mar 17 11:01:08 2006] [warn] FastCGI: server "C:/Program
Files/Apache Group/Apache2/fcgi-bin/mapserv.exe" (pid 552) terminated
with exit with status '128'
[Fri Mar 17 11:01:12 2006] [warn] FastCGI: server "C:/Program
Files/Apache Group/Apache2/fcgi-bin/mapserv.exe" restarted (pid 2636)
Files/Apache Group/Apache2/fcgi-bin/mapserv.exe" (pid 2636) terminated
Files/Apache Group/Apache2/fcgi-bin/mapserv.exe" has failed to remain
running for 30 seconds given 3 attempts, its restart interval has been
backed off to 600 seconds
[Fri Mar 17 11:02:07 2006] [warn] FastCGI: scheduled the start of the
last (dynamic) server "C:/Program Files/Apache
Group/Apache2/fcgi-bin/echo.exe" process: reached dynamicMaxClassProcs (1)
[Fri Mar 17 11:02:07 2006] [warn] FastCGI: (dynamic) server "C:/Program
Files/Apache Group/Apache2/fcgi-bin/echo.exe" started (pid 2008)
[Fri Mar 17 11:02:07 2006] [warn] FastCGI: server "C:/Program
[Fri Mar 17 11:02:08 2006] [warn] FastCGI: server "C:/Program
[Fri Mar 17 11:03:42 2006] [error] [client 127.0.0.1] (OS 2)The system
cannot find the file specified. : FastCGI: failed to connect to server
"C:/Program Files/Apache Group/Apache2/fcgi-bin/mapserv.exe":
CreateFile()/WaitNamedPipe() timed out
[Fri Mar 17 11:03:42 2006] [error] [client 127.0.0.1] FastCGI:
incomplete headers (0 bytes) received from server "C:/Program
[Fri Mar 17 11:06:11 2006] [warn] FastCGI: server "C:/Program
**END**
Now I have apache correctly configured to support fastcgi as evident by
1. An echo.exe fastcgi sample application correctly executing and
producing a listing of my environment variables
2. The mapserver that comes with the ms4w distribution correctly
executes when placed within my apache/fcgi-bin directory
I also have mapserver correctly configured to compile itself with
fastcgi support as evident by
1. the following lines in the nmake.opt file:
FCGIDIR=C:\sourcecode\fcgi-2.4.0\buildkit\fcgi-2.4.0
FCGILIB=C:\sourcecode\fcgi-2.4.0\buildkit\fcgi-2.4.0\libfcgi\Release\libfcgi.lib
FCGIINC=-IC:\sourcecode\fcgi-2.4.0\buildkit\fcgi-2.4.0\include
FCGIDEF=-DUSE_FASTCGI
2. Absence of any errors during compilation process.
So my question is -- any idea why mapserver is failing in fast cgi? --
the apache error code is border line useless to me. It should work but
it's not.
Thanks,
Clint
