MapServer 4.8.2
Paul Moen
pmoen at STATE.ND.US
Thu Mar 23 16:35:48 EST 2006
http://dl.maptools.org/dl/mapserver_Changelog.txt shows
>2006-01-31 05:43 umberto
> * HISTORY.TXT: Added comment for bug 1629
>2006-01-31 05:26 umberto
> * mappostgis.c: Revert behaviour to pre-1.61: do not allow for use
> of the FILTERITEM attribute (bug 1629)
But, 4.8.2 still had problems with queryByAttributes, which leads me to
believe that the patch for bug 1629 did not make it into 4.8.2.
I downloaded 4.8.2, applied the patch and querybyAttributes works as
expected.
I could be wrong.
Paul
On 3/10/06 1:54 AM, "Umberto Nicoletti" <umberto.nicoletti at GMAIL.COM> wrote:
> What about thi one:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1629 -
> queryByAttributes creates wrong WHERE clause on PostGIS layers
> On 3/10/06, Howard Butler <hobu at iastate.edu> wrote:
>> Let's release this baby. I propose we do it Wednesday, March 15th.
>> Some open bugs that might need some attention:
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1705 - Symbol
>> rotation leaks memory
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1684 - Pixmap SIZE
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1699 - Point
>> Queries in SDE throws an error
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1702 - Shapefile
>> handles getting left open in the case of bad data
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1700 - OGR
>> tileindex sources always opened as shapefiles
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1683 - configure.in
>> should be able to detect the Oracle "instant client" rpm distro
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1669 - msSaveMap()
>> should write out TRANSPARENCY ALPHA
>> There may be many others ;) Let's clean them up and get this out the door.
>> Howard
