Upgrade to Mapserver 4.8.2
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Mar 28 14:26:35 EST 2006
If you are doing embedded legends or scalebars then you would see the timeout problem.
Otherwise there is another issue of some sort...
Steve
>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 3/28/2006 7:00:45 AM >>>
Hi Sture,
I think the developers found a bug in 4.8.2 and will be releasing
4.8.3 immediately. It may be that your problem is related to this.
Cheers
Paul
On 28-Mar-06, at 7:54 AM, Sture Dingsøyr wrote:
> Hello
> I am running Mapserver 4.8.1 on my linux, all fine.
> But when i try to upgrade to 4.8.2 something happens.
> In my php script i get timeout after 30 sec...
> If i run phpinfo i get correct output stating that mapserver is
> correct installed.
> MapServer version 4.8.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> DEBUG=MSDEBUG
> Same if i try the CGI version of mapserver. It also sems to be
> working fine..
> I cant find anythinh in the httpd logs...
> Anybody got any ideas why my php script just timeout??
> Regards
> Sture
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
