Checking number of attributes in tile4ms
Mateusz Łoskot mateusz at LOSKOT.NET
Thu May 11 06:14:45 EDT 2006
Stephen Woodbridge wrote:
> Mateusz Łoskot wrote:
>> I noticed that tile4ms utility does not compare number of attributes, so
>> I applied small fix. So, tile4ms handles differences in attributes of
>> input layers exactly in the same way as ogrtindex.
>> Is there any interest of such changes?
>> If there is, I can provide a patch.
> Mateusz,
> I read through the bug and it looks like you have it correctly
> understood. I think this would be a good additional check for tile4ms.
> Please prepare a patch and attach it to the bug or open a new bug
> against tile4ms and attach it to that. I think Steve Lime will probably
> be assigned to it by default. It will be good to have ogrtindex and
> tile4ms behaving the same way.
Stephen,
I opened new but (#1777) and attached my patch:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1777
If there will be any problem, please give me some note.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
