RFC 17: Dynamic Array Sizing
Ned Harding
nharding at EXTENDTHEREACH.COM
Fri May 12 15:52:13 EDT 2006
Is there any reason not to just use C++? It would make stuff like this
trivial to do. MapServer already basically requires OGR which is C++,
I'd be surprised if its compiled anywhere without a C++ compiler.
And presuming that idea gets shot down, your RFC mentions growing stuff
1 object at a time. I've already fixed 1 bug like that in MapServer,
because when you have LOTS of objects that kills memory allocators and
performance. Growth should happen by a percentage so it doesn't have to
happen too often. I would recommend growing by at least 25% and double
every time rarely seems like a mistake.
Just my 2 cents,
Ned.
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
On Behalf Of Frank Warmerdam
Sent: Friday, May 12, 2006 12:48 PM
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-DEV] RFC 17: Dynamic Array Sizing
Folks,
There was yet another request for a mapserver compiled with larger sizes
for one of the MS_MAX* macros on #mapserver today, and it drove me over
the edge! I flipped out!
The result is RFC 17. I propose to spend a day overhauling MapServer to
use dynamic sizing for all the important "limits" (symbols, layers,
classes and styles).
http://mapserver.gis.umn.edu/development/rfc/ms-rfc-17
While it is open to discussion and ammendment, I'll accept votes even
now.
I won't actually implement it till after I'm done the RFC 16 work.
I'm going RFC crazy!
I furthermore unofficially propose the next version be called MapServer
5.0, code named "Dynamic Dodger" in honour of the alliterative Ubuntu
code names (ie. Breezy Badger, Dapper Duck).
Best regards
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGF,
http://osgeo.org
