RFC 17: Dynamic Array Sizing
Frank Warmerdam warmerdam at POBOX.COM
Mon May 15 09:18:37 EDT 2006
Ned Harding wrote:
>>   layerObj **layers;
>>   int numlayers; /* number of layers in mapfile */
>>   int maxlayers;
> Hey Frank,
> One request...  If you are going to change the meaning of the var layers
> or other similar vars, can you change the name?  ppLayers or something,
> frankly anything, so its made obvious to other code that links with it?
Ned,
Currently SWIG generated bindings allow script to access a layer as
map->layers[0].name.  This would continue to work even if the layers
became an array of pointers.  So I changing the name of layers would
essentially break all existing mapscript applications and for that reason
I think this change is a non-starter.
I would add we aren't in the habit of using hungarian style prefixes in
mapserver and I'm not that keen on introducing them widely.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
