RFC 17: Dynamic Array Sizing
Daniel Morissette
dmorissette at MAPGEARS.COM
Mon May 15 15:28:39 EDT 2006
Frank Warmerdam wrote:
> Ned Harding wrote:
>>> layerObj **layers;
>>> int numlayers; /* number of layers in mapfile */
>>> int maxlayers;
>> Hey Frank,
>> One request... If you are going to change the meaning of the var layers
>> or other similar vars, can you change the name? ppLayers or something,
>> frankly anything, so its made obvious to other code that links with it?
> Ned,
> Currently SWIG generated bindings allow script to access a layer as
> map->layers[0].name. This would continue to work even if the layers
> became an array of pointers. So I changing the name of layers would
> essentially break all existing mapscript applications and for that reason
> I think this change is a non-starter.
I would tend to agree with Ned that changing the meaning of a variable
in a data structure without changing its name is asking for trouble.
PHP MapScript never accesses layers, classes and styles by index
directly, you must go through a get() method all the time. Doesn't SWIG
MapScript have the same get() methods? Could we not hide the arrays and
enforce the use of get() methods?
> I would add we aren't in the habit of using hungarian style prefixes in
> mapserver and I'm not that keen on introducing them widely.
Agreed.
Daniel
Daniel Morissette
http://www.mapgears.com/
