Checking number of attributes in tile4ms
Mateusz Łoskot
mateusz at LOSKOT.NET
Tue May 16 01:43:59 EDT 2006
Stephen Woodbridge wrote:
> Mateusz Łoskot wrote:
>> Hi,
>> Recently, I was fixing some GDAL issue reported by Bart
>> (http://bugzilla.remotesensing.org/show_bug.cgi?id=1144)
>> and I added tests of attributes scheman in input layers to ogrtindex
>> utility.
>> As discussed on Bugzilla
>> (http://bugzilla.remotesensing.org/show_bug.cgi?id=1144#c4)
>> it's recommended to check number of attributes, and if number is same,
>> schema of attributes.
>> I noticed that tile4ms utility does not compare number of attributes, so
>> I applied small fix. So, tile4ms handles differences in attributes of
>> input layers exactly in the same way as ogrtindex.
>> Is there any interest of such changes?
>> If there is, I can provide a patch.
>> Cheers
> Mateusz,
> I read through the bug and it looks like you have it correctly
> understood. I think this would be a good additional check for tile4ms.
> Please prepare a patch and attach it to the bug or open a new bug
> against tile4ms and attach it to that. I think Steve Lime will probably
> be assigned to it by default. It will be good to have ogrtindex and
Hi Stephen,
Have you checked the bug report 1777 I submitted?
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1777
Could you check if the patch is working/well done?
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
