RFC 16: MapScript WxS Services
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri May 19 09:13:04 EDT 2006
Hi There,
For me at the end of the day, having ogc services available through
mapscript is the most imporatant part of all this. As mentionned, there
could be another project/RFC to adress Tamas concerns, but I would hate
to "loose" this feature now. I would vote +1 and would certainly try to
syn the php mapscript to the new additions.
Best Regards,
Frank Warmerdam wrote:
> Stephen Woodbridge wrote:
>> So I'll vote +0 (neutral but ok to proceed) on your proposal as is. I
>> think it would be a big win if you and Tamas could collaborate on this
>> in some way, but if I recall correctly you already have your proposal
>> roughly implemented and ready to check in if approved, so a delay
>> might be painful.
> Steve,
> A modest delay isn't the end of the world. I don't mind revising my
> proposal in response to specific suggestions as long as they seem
> reasonable.
> I think Tamas's main thrust is the need for "io contexts" for the msIO
> layer. I don't disagree that this would be desirable, but I would *claim*
> that this is largely decoupled from my proposal. It can be as easily
> pursued separately as together with RFC 16.
> Furthermore, I'm already working pretty cheaply in implementing the
> mapscript
> work for my client. Adding in responsible to restructure essentially all
> mapserver io to use io contexts would dramatically increase the effort,
> risk and time to completion. So I feel loading io contexts onto RFC 16 is
> unwarranted. I also have substantial reservations about the ability for
> us to implement io contexts without substantial disruption to existing
> mapscript applications.
> So I would prefer to see any RFC on io contexts broad forward on as it's
> own RFC, and judged on it's own merits.
> Best regards,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
