RFC-18: Encryption of passwords in mapfiles
Daniel Morissette dmorissette at MAPGEARS.COM
Fri May 26 16:16:11 EDT 2006
Thanks for the feedback. I have updated MS-RFC-18 to:
- Use TEA for encryption/decryption instead of OpenSSL
- Use hex encoding instead of PEM (base64)
- Added a note about looking for pairs of { + } with just hex encoding
chars in between
- Added a question about whether we should use a new ENCRYPTION_KEY
keyword in the mapfile instead of CONFIG MS_ENCRYPTION_KEY (this came up
on IRC)
Daniel
Frank Warmerdam wrote:
> Daniel Morissette wrote:
>> Do you see this as a blocker issue?
> Daniel,
> Not necessarily.
>> Perhaps the msDecryptString() function could look for a pair of { + },
>> and then verify that all chars in the block are valid base 64 encoding
>> chars before proceeding with decryption. That should significantly
>> reduce the chances of a false match. What do you think?
> I think this would be a great idea.
>> Another alternative would be to only allow encrypting the full
>> connection string in one chunk, but it would be harder to maintain
>> mapfiles this way.
> Right.  I think it is much preferrable to just apply it to the password.
>> I liked PEM (base 64) encoding because it is apparently the most
>> compact way to encode binary data using printable chars. It increases
>> the data size by a ratio of 4:3 instead of 2:1 for hex encoding. I had
>> also found an implementation covered by a MIT license at
>> http://base64.sourceforge.net/.
> I can't imagine efficiency is very important in this context.  And a more
> limited grammar of characters might make the validation described above
> safer.
> Best regards,
Daniel Morissette
http://www.mapgears.com/
