Compile errors building Python Mapscript using win32 buildkit
Jeff McKenna jmckenna at DMSOLUTIONS.CA
Wed May 31 10:01:19 EDT 2006
When building Python Mapscript, with MapServer CVS head, I get the
following compile errors (other mapscripts build fine, and for ms 4.8.3
this does not occur):
    C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\bin\link.exe
/DLL /nologo /INCREMENTAL:NO
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\postgresql-8.1.2/src/interfaces/libpq/release
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\gd-2.0.33
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\PDFlib-Lite-6.0.2/libs/pdflib/Release_DLL
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\zlib-1.2.3
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\geos-2.2.2/source
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\jpeg-6b
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\libpng-1.2.8\projects\visualc71\Win32_LIB_Release
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\proj-4.4.9/src
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\curl-7.15.0
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\libiconv-1.9.1\lib
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\freetype-2.1.10/objs
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\ming-0.2a/src
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\mapserver\..\gdal-1.3.2
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\Python-2.4.2\libs
/LIBPATH:D:\build\mapserver-buildkit-4.8.3-2\buildkit\Python-2.4.2\PCBuild
mapserver_i.lib /EXPORT:init_mapscript
build\temp.win32-2.4\Release\mapscript_wrap.obj
build\temp.win32-2.4\Release\pygdioctx/pygdioctx.obj
/OUT:build\lib.win32-2.4\_mapscript.pyd
/IMPLIB:build\temp.win32-2.4\Release\_mapscript.lib
    Creating library build\temp.win32-2.4\Release\_mapscript.lib and
object build\temp.win32-2.4\Release\_mapscript.exp
mapscript_wrap.obj : error LNK2019: unresolved external symbol _gdFree
referenced in function _imageObj_write
_gdImageDestroy referenced in function _delete_symbolObj
build\lib.win32-2.4\_mapscript.pyd : fatal error LNK1120: 2 unresolved
externals
Are others running into this?
jeff
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
