server-side SLD support
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Wed Nov 1 11:12:14 EST 2006
Bart van den Eijnden (OSGIS) wrote:
> Good questions Daniel. Let me try and answer them. I am sure Assefa will
> correct me if necessary :-)
> 1) I have no problem with a shorter keyword like SLD
> 2) saving a MAP file will probably just save all the generated classes. I
> don't see a problem with this approach.
This is still an issue for me, if you save the map and reload it, the
same classes will be regenrated when we read the SLD tag. is this
acceptable ?
> 3) I don't think get/set functions for Mapscript are necessary since there
> is already a Mapscript function to generate them (applySLDURL on the
> MapObj).
  I agree with this.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Daniel Morissette <dmorissette at MAPGEARS.COM>
> Naar: MAPSERVER-DEV at LISTS.UMN.EDU <MAPSERVER-DEV at LISTS.UMN.EDU>
> Onderwerp: Re: [UMN_MAPSERVER-DEV] server-side SLD support
> Datum: 01/11/06 13:49
>>&gt;
>>&gt; Our plan is to add server-side SLD support to Mapserver WMS. This
> would
>>&gt; involve adding a new keyword, for instance STYLEDLAYERDESCRIPTOR. It
> will
>>&gt; add classes from the SLD document (matching the layer's name) to the
> LAYER.
>>&gt;
>>I like the idea in general.
>>A few questions/comments:
>>- How'bout a shorter keyword such as SLD instead of STYLEDLAYERDESCRIPTOR?
>>- What happens if you save a mapfile ($map-&gt;save()) that contains SLD
>>definitions like this? Are they maintained in the saved mapfile or lost?
>>- Are there ways to get and set SLD's via MapScript and if yes how does
>>that work? i.e. does MapScript turn the SLD into a set of classes right
>>away, or is the SLD just a string member of layerObj... actually an
>>array of strings... or sldObj's? um... fun questions to answer...
>>Daniel
>>Daniel Morissette
>>http://www.mapgears.com/
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
