server-side SLD support
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Thu Nov 2 03:27:38 EST 2006
Steve,
to be honest I personally don't see a use case/necessity for mixing the two.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Steve Lime <Steve.Lime at DNR.STATE.MN.US>
Naar: MAPSERVER-DEV at LISTS.UMN.EDU <MAPSERVER-DEV at LISTS.UMN.EDU>
Onderwerp: Re: [UMN_MAPSERVER-DEV] server-side SLD support
Datum: 01/11/06 21:36
> Why would someone want to mix SLD and MapServer classes? Is there an
> obvious
> use case? I like the idea (for non-OWS use as well), but would prefer
> keeping things
> simple.
> Steve
> >>> Daniel Morissette <dmorissette at MAPGEARS.COM> 11/1/2006
3:30 PM >>>
> Yewondwossen Assefa wrote:
> > I am more leaning to say that we should not save the classes
> generated,
> > but only the SLD (marking the classes as temporary as you suggested).
> > But when we talk about save, it is done through mapscript, so the
> users
> > will have the ability to manipulate the classes before saving the map
> > and next reload of the map will givent diffrent result.
> > If it is a documented and acceptable limitation, I do not see any
> > problem discarding the new classes created.
> This kind of inconsistent behavior makes me nervous. What you propose
> reopens the questions that I sent earlier this morning.
> I mean someone could load a mapfile with MapScript, not knowing that it
> contained a SLD ref. Then modify a few classes (including some coming
> from a SLD) or insert new classes and save the map, expecting the
> changes to be saved, but then because the MapScript code was not
> SLD-aware the changes would actually be lost and odd side-effects might
> happen next time the saved map is loaded.
> I'm also not clear on whether the current ApplySLD() method is
> sufficient for MapScript apps to interact with this feature if you plan
> to maintain both the SLD ref and a set of temporary classes in memory.
> >> Maybe if we don't allow people to mix SLD and CLASSes, it would
make
> >> life easier? But still the generated classes would need to be
> removed
> >> and the SLD keyword written upon saving.
> > I still think we should allow the mixing of SLD and CLASS elements
> and
> > mark SLD generated classes as "non savable"
> Mixing SLD and CLASS elements would be nice, but if that becomes the
> source of odd side-effects for apps that are not SLD-aware then that's
> not good.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
