building and testing options
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Tue Nov 7 15:17:26 EST 2006
Im writing mapowscommon.c, I've come across some issues to which some
advisory would be appreciated.
1./ I usually compile C code with:
(on Linux)
$ gcc -ansi -pedantic -Wall -O foo.c
MapServer has -Wall and -O2 already as part of the build process. Would
the other flags be useful for MapServer? I use them because they
support C ISO. See `man gcc` for more info.
2./
Should we be doing some sort of structured memory debugging? For
example, do people use tools like valgrind when building? If not,
should we (presumably against a few use cases for the code)?
Thanks
..Tom
