summary on server-side SLD support
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Tue Nov 7 21:34:09 EST 2006
Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> a lot of discussion, in my opinion the wanted behaviour would be:
> 1) new keyword SLD which can reference a file or url
> 2) classes are loaded into layer but are immutable (cannot be changed, use a
> flag for this)
> 3) when saving the MAP object, the generated classes are not saved and only
> the SLD keyword plus its value is saved.
> I think if you link in a style from an external SLD document (in a Mapscript
> session eg with Chameleon), you want to take into account changes in this
> SLD document into your map image. That's one of the points of working with
> an external document for styles.
> Is this also the perception of the others, i.e. can we agree on this?
     One point to clarify : Using php mapscript, we could add tests on
the different setters functions so the immutable classes would not be
modified.  Could the same be done in the other mapscript flavors ?
> Thanks in advance.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
