Perl module version checking
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Wed Nov 15 15:18:57 EST 2006
Mapscript defines MS_VERSION to derive the version of mapscript used (i.e. 4.10.0, etc.).
Perl language allows for specifying modules by version, i.e.:
#!/usr/bin/perl
use strict;
use warnings;
use mapscript 4.10.0;
Perl language processes this by checking the version specified against the VERSION variable used to identify Perl modules.
When attempting the script snippet above, the result is:
mapscript does not define $mapscript::VERSION--version check failed at proxim2prop.pl line 9.
BEGIN failed--compilation aborted at foo.pl line 9.
I have run into a couple of situations where version checking like this is required.
Suggest we add a VERSION variable to mapscript.pm. I think it would be valuable given the issue above, and especially since it is Perl idiom to do so.
Comments?
..Tom
