Hide tileindex layer
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Nov 16 17:39:02 EST 2006
Doesn't look like that got documented although it was talked about as
part of one of
the various GML3L0 bugs. There's a metadata value called
"gml_geometries" that allows
you to specify the geometry types used for the layer, you can set more
than and the GML encoder
will choose the right one based on the shape properties and its type.
You can also set gml_geometries "none" and that will supress output of
the coordinates.
See http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1718...
Probably should create a documentation bug then.
Steve
>>> Daniel Morissette <dmorissette at MAPGEARS.COM> 11/16/2006 4:03:06 PM
Steve Lime wrote:
> Denis: The geometry case is handled already through a bunch of GML
> metadata tags
> I wrote last summer. Geometries and attributes can be supressed on a
> layer by layer
> basis. There are no WEB metadata equivalents for those.
How do you control geometry? I barely remember talking about
controlling
geometries but I don't see anything in the docs at
http://mapserver.gis.umn.edu/docs/howto/wfs_server/#layer-object
Daniel
Daniel Morissette
http://www.mapgears.com/
