Connecting a ArcSDE db
Hallgren Johan E
jhhal at WMDATA.COM
Fri Nov 24 06:34:46 EST 2006
Hello,
I use mapServer and connect to a Oracle Spatial/ArcSDE database. I use
the direct connect alternative.
When I use the getFeature function, I've get an error. The reason is
that ArcSDE creates a blob-SE_ANNO_CAD_DATA column. How is the best way
to solve that, I have tried the subselect alternative (DATA
"[geom_column] FROM (SELECT [columns] FROM [table]|[Spatial
function])"). Is there other, better options?
/Johan
___________________________________
Johan Hallgren
WM-data a LogicaCMG company
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-547 46 (int: +46-2354746)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
<BLOCKED::mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se
<BLOCKED::/exchweb/bin/redir.asp?URL=http://www.wmdata.se/>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20061124/6b5be379/attachment.html
