queryByAttributes with IN (arg)
Hallgren Johan E jhhal at WMDATA.COM
Fri Nov 24 08:37:17 EST 2006
Sorry, the first mail went away...
I tries to use MapServer and Oracle Spatial. Shouldn't the following
statement work?
strWhere = "KOPPLINGSID in (6246,4730,4123)";
strFld  = "KOPPLINGSID";
oLayerObj.queryByAttributes(m_MapObj, strFld, strWhere,
mapscript.MS_MULTIPLE);
In the console I can read:
msOracleSpatialLayerOpen called with: shape FROM (SELECT rownum,
OBJECTID, GISSG
UID, KOPPLINGSID, XMAX, YMAX, XMIN, YMIN, DATNY, DATEDIT, NAMNNY,
NAMNEDIT, shap
e FROM FAT.GFAST ) USING NONE
msOracleSpatialLayerOpen. Shared connection not available. Creating one.
msConnPoolRegister(Fast,imsuser/imsuser at gisstest.world,00D85C68)
msOracleSpatialLayerFreeItemInfo was called.
msOracleSpatialLayerInitItemInfo was called.
msOracleSpatialLayerWhichShapes was called.
msOracleSpatialLayerWhichShapes. Using this Sql to retrieve the data:
SELECT row
num, KOPPLINGSID, shape FROM (SELECT rownum, OBJECTID, GISSGUID,
KOPPLINGSID, XM
AX, YMAX, XMIN, YMIN, DATNY, DATEDIT, NAMNNY, NAMNEDIT, shape FROM
FAT.GFAST ) W
HERE KOPPLINGSID in
msOracleSpatialLayerClose was called. Layer connection:
.world
msOracleSpatialLayerClose. Cleaning layerinfo handlers.
msOracleSpatialLayerClose. Cleaning Oracle handlers.
msConnPoolRelease(Fast,imsuser/imsuser at gisstest.world,00D85C68)
The parenthesis with the argument is removed.
Is the in statement not supported in mapserver?
/Johan
___________________________________
Johan Hallgren
WM-data a LogicaCMG company
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-547 46 (int: +46-2354746)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
<BLOCKED::mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se
<BLOCKED::/exchweb/bin/redir.asp?URL=http://www.wmdata.se/>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20061124/41885fc6/attachment.html
