Manage ArcSDE Versions
Paolo Corti pcorti at GMAIL.COM
Mon Nov 27 10:20:46 EST 2006
Hello Johan
ArcSde versions may be managed only by ArcObjects (like ArcMap does). This
meaning that the same ArcIms (at least until 9.0) can't manage versions
unless you don't serve ArcMap map services with ArcObjects runtime
installed. I am almost sure that also MapServer can't handle geodatabase
versions, but maybe Howard Butler can confirm this for sure
best regards
Paolo Corti
GIS Developer
http://www.paolocorti.net
Hallgren Johan E wrote:
> Newer versions of ArcSDE manage versions of the records. It means that
> the clients (ArcMap) can create a version, do editing, and post it back
> to the default version (business table).
> If we connect from MapServer when will we se an updated version.
> ArcSDE is using Oracle Spatial as database.
> /Johan
> ___________________________________
> Johan Hallgren
> WM-data a LogicaCMG company
> Pelle Bergs backe 3
> Box 1938, 791 19 Falun
> Tel: 023-547 46 (int: +46-2354746)
> Mobil: 070-588 44 28 (int: +46-705884428)
> johan.e.hallgren at wmdata.com
> http://www.wmdata.se
View this message in context: http://www.nabble.com/Manage-ArcSDE-Versions-tf2698678.html#a7561729
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
