mapserver WMS time and postgis.
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Oct 4 15:54:09 EDT 2006
Denis,
Sorry for the delay.
Please enter a bug (WMS Server module) and code contribution and I
will integrate it in mapserver.
Thanks.
Denis Nadeau wrote:
> Hi,
> I would like to change some of the code in mappostgis.c to reflect C
> 5.2 Nearest Value instructions found in WMS 1.1.1 specifications for
> "TIME" parameter.
> http://portal.opengeospatial.org/files/?artifact_id=1081&version=1&format=pdf
> <http://portal.opengeospatial.org/files/?artifact_id=1081&version=1&format=pdf>
> Here what it says in the WMS 1.1.1 doc.
> "If a request does includes an imprecise dimensional value, and nearest
> value behavior has been declared, then the server shall compute and send
> the nearest available value. The value shall be rounded, not merely
> truncated."
> Right now, mapserver is using date_trunc function to allow the user to
> specify months, days, hours or minutes. I think this could be enhanced
> to get the nearest time value in Postgres. For example, NASA GES has 3
> hourly data. If the user specify 2006-09-28T02:00 a blank image is
> return, the user needs to be exact 2006-09-28T03:00. Same thing with
> 10-day data, 2006-09-03 will return a blank image. User have to hit
> the right date 2006-08-10, 2006-08-20, 2006-08-31, 2006-09-10,....
> Example
> Tropical Rain data 3B42_V6_10_DAY:
> http://g0hep12u.ecs.nasa.gov/mapserv-bin/wms_ogc?SERVICE=WMS&VERSION=1.1.1&REQUEST=Getmap&layers=bluemarble,TRMM_3B42_V6_10_DAY&BBOX=-180,-50,180,50&TIME=2005-08-20
> <http://g0hep12u.ecs.nasa.gov/mapserv-bin/wms_ogc?SERVICE=WMS&VERSION=1.1.1&REQUEST=Getmap&layers=bluemarble,TRMM_3B42_V6_10_DAY&BBOX=-180,-50,180,50&TIME=2005-08-20>
> blank image
> http://g0hep12u.ecs.nasa.gov/mapserv-bin/wms_ogc?SERVICE=WMS&VERSION=1.1.1&REQUEST=Getmap&layers=bluemarble,TRMM_3B42_V6_10_DAY&BBOX=-180,-50,180,50&TIME=2005-08-20T04:00
> <http://g0hep12u.ecs.nasa.gov/mapserv-bin/wms_ogc?SERVICE=WMS&VERSION=1.1.1&REQUEST=Getmap&layers=bluemarble,TRMM_3B42_V6_10_DAY&BBOX=-180,-50,180,50&TIME=2005-08-20T04:00>
> Let me know if this make sense to you. I would be happy to contribute
> some coding for this.
> Denis
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
