Filter in Mapserver 4.10.0
Daniel Morissette dmorissette at MAPGEARS.COM
Tue Oct 24 11:25:03 EDT 2006
Can you please create a bug and add a note to the 4.10 HISTORY.TXT about
this... the users will thank you.
Daniel
Steve Lime wrote:
> Ok, found and fixed the problem. It wasn't an issue with the lexer changes Paul refers to
> rather an issue with some cleanup done in loadExpressionString in mapfile.c. I made a
> mistake and let the lexer check for simple expression strings when in reality that's should
> be the default case if an expression is not a regex, logical or case insensitive.
> I have fixed in both 4.10 and 5.0 if anyone would care to confirm...
> Steve
>>>> Steve Lime <Steve.Lime at DNR.STATE.MN.US> 10/23/06 12:33 PM >>>
> Will look into it...
> Steve
>>>> Paul Ramsey <pramsey at REFRACTIONS.NET> 10/19/2006 2:59:10 PM >>>
> I assume this traces back to this commit:
> revision 1.101
> date: 2006/08/15 06:18:49;  author: sdlime;  state: Exp;  lines: +5 -34
> Simplified quoted string rules in maplexer.l, just or'd together the
> single and
> double qoute regular expressions. Updated include detection to
> support single
> quotes as well.
> On 19-Oct-06, at 12:21 PM, Andreas Albarello wrote:
>> Sture Dingsøyr wrote:
>>> The code below fails:
>>> $poLayer = $mapObject->getLayerByName($layerId[$i]);
>>> $poLayer->set("status", 1);
>>> $poLayer->setFilter("navn = 'Fjaler'");
>>> I get this error message:
>>> DECLARE mycursor BINARY CURSOR FOR SELECT asbinary(force_collection
>>> (force_2d(the_geom)),'NDR'),gid::text from (SELECT * FROM
>>> n2000ko_f) AS n2000ko_f WHERE (navn = ) and (the_geom && setSRID
>>> ( 'BOX3D(-647132 6410334.17468806,1689132
>>> 7988665.82531194)'::BOX3D,32633) )
>> Sture,
>> I've experienced exactly the same problem with Mapserver 4.10.0.
>> Don't know if this should be considered a bug, but it is a
>> backwards compatibility issue with existing mapscript applications
>> at least. I believe this behavior has been caused by some recent
>> changes to the mapfile lexer.
>> There's however a workaround for this. The following should do the
>> trick:
>> $poLayer->setFilter("\"navn = 'Fjaler'\"");
>> Best regards,
>> Andreas Albarello
>> Analysis & SW Development
>> Territorium Online srl/GmbH
>> Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
>> email: andreas.albarello at territoriumonline.com
>> web:   www.territoriumonline.com
Daniel Morissette
http://www.mapgears.com/
