GD library error. Invalid bitmap font
Hallgren Johan E
jhhal at WMDATA.COM
Tue Oct 31 09:48:51 EST 2006
It wasn't so easy to know but now it works for me to,
MANY THANKS.
Johan
___________________________________
Johan Hallgren
WM-data a LogicaCMG company
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-547 46 (int: +46-2354746)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
http://www.wmdata.se
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
On Behalf Of Tamas Szekeres
Sent: den 31 oktober 2006 15:14
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] GD library error. Invalid bitmap font
Johan,
You have created a new labelObj instead of using classObj.label.
Therefore you should replace 'labelObj oLabelObj = new labelObj();'
with labelObj oLabelObj = oClassObj.label;
In addition you should remove 'oMapObj.insertLayer(oLayerObj, -1);' to
prevent from adding the layer to the map twice. The layer has already
been added at the construction of the layer 'layerObj oLayerObj = new
layerObj(oMapObj);'
Best Regards,
Tamas
2006/10/31, Hallgren Johan E <jhhal at wmdata.com>:
> Hello Tamas
> Here is a code snippet
> mapObj oMapObj = new mapObj(mapFile.Text);
> layerObj oLayerObj = new layerObj(oMapObj);
> oLayerObj.name = "textLayer";
> oLayerObj.type = MS_LAYER_TYPE.MS_LAYER_ANNOTATION;
> oLayerObj.connectiontype = MS_CONNECTION_TYPE.MS_INLINE;
> oLayerObj.status = 1;
> classObj oClassObj = new classObj(oLayerObj);
> oLabelObj.type = MS_FONT_TYPE.MS_TRUETYPE;
> oLabelObj.font = "verdanab";
> oLabelObj.color = new colorObj(120, 220, 10, -4);
> oLabelObj.size = 12;
> oLabelObj.antialias = mapscript.MS_TRUE;
> oLabelObj.encoding = "CP437";
> oLabelObj.maxsize = 256;
> oLabelObj.minsize = 4;
> bool isDatabaseCoord = false;
> lineObj oLineObj = new lineObj();
> oLineObj.add(getPointObj("50 50", isDatabaseCoord, oMapObj));
> shapeObj oShapeObj = new shapeObj((int)MS_SHAPE_TYPE.MS_SHAPE_POINT);
> oShapeObj.add(oLineObj);
> string strVal = "Johan Hallgren";
> oShapeObj.text = strVal;
> oLayerObj.addFeature(oShapeObj);
> imageObj i_obj = null;
> i_obj = oMapObj.draw();
> string fn = "c:\\temp\\" + GetTempFileName() + "." +
> i_obj.format.extension;
> i_obj.save(fn, oMapObj);
> pictureBox2.Image = Image.FromFile(fn);
> Function used:
> private pointObj getPointObj(string str, bool isDatabaseCoord, mapObj
> mo)
> double x;
> double y;
> if (!isDatabaseCoord)
> GMSAgent_WP.Libs.Envelope currentExtent = new
> GMSAgent_WP.Libs.Envelope(mo);
> x = currentExtent.FromMapX(Convert.ToInt32(str.Split('
> ')[0]));
> y = currentExtent.FromMapY(currentExtent.ImageHeight -
> Convert.ToInt32(str.Split(' ')[1]));
> else
> x = GenericIMS_lib.Libs.Utilities.ToDouble(str.Split('
> ')[0]);
> y = GenericIMS_lib.Libs.Utilities.ToDouble(str.Split('
> ')[1]);
> pointObj oPointObj = new pointObj(x, y, 0, -2e38);
> return oPointObj;
> On the row i_obj = oMapObj.draw(); I've get the following error.
> msGetBitmapFont(): GD library error. Invalid bitmap font. Must be one
of
> tiny, small, medium, large or giant.
> This is mu mapfile:
> # Start of map file
> MAP
> NAME WMSE
> STATUS ON
> EXTENT 1194973 6083188 1973312 7687503
> SIZE 600 600
> UNITS METERS
> IMAGECOLOR 255 255 255
> # TEMPLATEPATTERN "itasca"
> FONTSET "C:\Project\applications\GMS\GMSAgent\MapFiles\fonts.txt"
> SYMBOLSET
> "C:\Project\applications\GMS\GMSAgent\MapFiles\Symbol\symbolset.sym"
> SHAPEPATH "C:\Project\DATA\/GIMS"
> RESOLUTION 200
> DEBUG OFF
> IMAGETYPE PNG
> # Start of web interface definition (including WMS enabling
metadata)
> WEB
> # HEADER templates/header.html
> TEMPLATE "c:\temp\template.txt"
> # FOOTER templates/footer.html
> MINSCALE 1000
> MAXSCALE 1550000
> IMAGEPATH "set in index.html"
> IMAGEURL "set in index.html"
> LOG "c:\temp\ms.log"
> END
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS ON
> END
> # Start of reference map
> # Start of layer definitions
> # LAYER
> # NAME sj_large_os
> # TYPE POLYGON
> # STATUS OFF
> # CONNECTION "OCI:tfk/tfk at wmsi1394"
> # CONNECTIONTYPE OGR
> # DATA "sj_large_os"
> # CONNECTION "tfk/tfk at wmsi1394"
> # CONNECTIONTYPE oraclespatial
> # DATA "shape from sj_large_os"
> # TEMPLATE "c:\temp\template.txt"
> # DEBUG on
> # CLASS
> # STYLE
> # OUTLINECOLOR 0 0 255
> # COLOR 255 0 0
> # END
> # END
> # END
> # LAYER
> # NAME SJ_large_SDE
> # TYPE POLYGON
> # STATUS OFF
> # CONNECTION "wmsi001394,port:5151,wmgis,wmgis,wmgis01"
> # CONNECTIONTYPE SDE
> # DATA "SJ_large_sde,shape"
> # DEBUG on
> # CLASS
> # STYLE
> # COLOR 255 0 0
> # END
> # END
> # END
> # LAYER
> # NAME SJ_large_SDO
> # TYPE POLYGON
> # STATUS OFF
> # DATA "SJ_large_sdo,shape"
> # DEBUG on
> # CLASS
> # STYLE
> # COLOR 255 0 0
> # END
> # END
> # END
> # LAYER
> # NAME SJ_large_SDO_Direct
> # TYPE POLYGON
> # STATUS OFF
> # CONNECTION "wmgis/wmgis01 at wmsi1394"
> # DATA "shape FROM (SELECT objectid, shape, KKOD FROM SJ_large_sdo)
> USING UNIQUE OBJECTID VERSION 10g"
> # DEBUG on
> # CLASS
> # STYLE
> # COLOR 255 0 0
> # END
> # END
> # END
> # LAYER
> # NAME Fastigheter
> # TYPE POLYGON
> # STATUS OFF
> # CONNECTION "wfast/wfast at skogdb"
> # DATA "shape FROM fastighetsytor USING UNIQUE OBJECTID VERSION
10g"
> # MAXSCALE 100000
> # DEBUG on
> # CLASS
> # MAXSCALE 100000
> # MINSCALE 20000
> # STYLE
> # OUTLINECOLOR 0 0 0
> # WIDTH 1
> # END
> # END
> # CLASS
> # MAXSCALE 20000
> # STYLE
> # SYMBOL dashed
> # OUTLINECOLOR 240 240 240
> # WIDTH 2
> # END
> # END
> # END
> # LAYER
> # NAME "Fastigheter Namnjh"
> # STATUS ON
10g"
> # TYPE POLYGON
> # MAXSCALE 20001
> # LABELITEM "FASTIGHET"
> # CLASS
> # LABEL
> # TYPE truetype
> # FONT verdanab
> # SIZE 8
> # COLOR 240 240 240
> # END
> # END
> # END
> # LAYER
> # NAME BergvikMark_SDE
> # TYPE POLYGON
> # STATUS OFF
> # DATA "bergvikmark,shape"
> # DEBUG off
> # CLASS
> # STYLE
> # COLOR 255 0 0
> # END
> # END
> # END
> LAYER
> NAME sj
> TYPE POLYGON
> STATUS ON
> DATA vv/sj
> MAXSCALE 750000
> CLASS
> STYLE
> COLOR 165 250 255
> END
> END
> END
> LAYER
> NAME sj_large
> TYPE POLYGON
> STATUS ON
> DATA vv/sj_large
> MINSCALE 750000
> CLASS
> STYLE
> COLOR 165 250 255
> END
> END
> END
> LAYER
> NAME rsv_hv_grid
> TYPE POLYGON
> STATUS ON
> DATA vv/rsv_hv_grid
> MINSCALE 30000
> CLASS
> STYLE
> COLOR 165 250 255
> END
> END
> END
> LAYER
> NAME Or
> TYPE POLYGON
> STATUS ON
> DATA vv/Or
> MAXSCALE 300000
> MINSCALE 30000
> CLASS
> STYLE
> OUTLINECOLOR 0 130 255
> COLOR 255 255 255
> END
> END
> END
> LAYER
> NAME TATYT
> TYPE POLYGON
> STATUS ON
> DATA vv/TATYT
> MAXSCALE 1000000
> CLASS
> STYLE
> OUTLINECOLOR 0 0 0
> COLOR 210 210 210
> END
> END
> END
> LAYER
> NAME vdb_m
> TYPE LINE
> STATUS ON
> DATA vv/vdb_m
> MAXSCALE 2000000
> CLASS
> EXPRESSION ([VAEGNR] > 1 AND [VAEGNR] < 100)
> STYLE
> SYMBOL solid
> SIZE 2
> COLOR 105 105 105
> END
> END
> CLASS
> MAXSCALE 1000000
> EXPRESSION ([VAEGNR] >= 100 AND [VAEGNR] <
500)
> STYLE
> SYMBOL solid
> SIZE 2
> COLOR 105 105 105
> END
> END
> CLASS
> MAXSCALE 1000000
> EXPRESSION ([VAEGNR] >= 500)
> STYLE
> COLOR 105 105 105
> END
> END
> END
> LAYER
> NAME Granser
> TYPE LINE
> STATUS ON
> DATA vv/Granser
> CLASS
> EXPRESSION ([TYP] = 5)
> STYLE
> SYMBOL dot
> COLOR 255 173 0
> SIZE 2
> END
> END
> CLASS
> EXPRESSION ([TYP] = 6)
> STYLE
> COLOR 255 173 0
> END
> END
> CLASS
> EXPRESSION ([TYP] = 7)
> STYLE
> COLOR 255 173 0
> END
> END
> CLASS
> EXPRESSION ([TYP] = 8)
> STYLE
> SYMBOL solid
> COLOR 255 173 0
> SIZE 2
> END
> END
> END
> LAYER
> NAME vd
> TYPE LINE
> STATUS ON
> DATA vv/vd
> MAXSCALE 500000
> CLASS
> STYLE
> COLOR 0 219 255
> END
> END
> END
> LAYER
> NAME TATTXT
> TYPE LINE
> STATUS OFF
> DATA vv/TATTXT
> MAXSCALE 1250000
> LABELITEM "TEXT"
> CLASS
> LABEL
> ENCODING CP437
> TYPE truetype
> FONT verdanab
> SIZE 10
> END
> END
> END
> LAYER
> NAME SMAORTTX
> TYPE LINE
> STATUS OFF
> DATA vv/SMAORTTX
> MAXSCALE 1250000
> LABELITEM "TEXT"
> CLASS
> LABEL
> ENCODING CP437
> TYPE truetype
> FONT verdana
> SIZE 8
> END
> END
> END
> LAYER
> NAME "Raster, sth"
> STATUS OFF
> TILEINDEX "Rasterdata/d3/index.shp"
> TILEITEM "Location"
> TYPE RASTER
> END
> END # Map File
> Good luck
> /Johan
> Johan Hallgren
> Pelle Bergs backe 3
> From: Tamas Szekeres [mailto:szekerest at gmail.com]
> Sent: den 27 oktober 2006 23:26
> To: Hallgren Johan E
> Cc: MAPSERVER-DEV at lists.umn.edu
> Subject: Re: GD library error. Invalid bitmap font
> Would you post a code fragment that adds the text to this layer
inline?
> Tamas
> 2006/10/27, Hallgren Johan E <jhhal at wmdata.com>:
> > Hello
> > In the migration from MapServer 4.8 to mapserver 4.10 I have problem
> when
> > adding text to the Map.
> > This is the error message I've get:
one
> of
> > A add texts in runtime and as far as I know the only size I set is
> > And I don't use bitmap fonts, I use
> > My environment is CSharp, VS 2005.
> > Could anyone give me a hint about what this is all about?
> > /Johan
> > Johan Hallgren
> > Pelle Bergs backe 3
