Mapserver compilation flags should be added to the SWIG
command line
Tamas Szekeres
szekerest at GMAIL.COM
Fri Sep 1 16:20:30 EDT 2006
I would also highly discourage the enlargement the size of the
pointObj structure needlessly. Especially when the structure is a
subject of frequent allocations and deallocations and high number of
the particular structure may reside in the memory.
And also the SWIG interface should not hide the Z and M members when
USE_POINT_Z_M is switched on.
However I still couldn't understand the reason of that performance
degradation since only indexed array access and struct member access
are taking place.
Tamas
2006/9/1, Daniel Morissette <dmorissette at mapgears.com>:
> That was bug 1244:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1244
> Unfortunately this bug report doesn't contain detailed profiling
> results, just total times to render a map, but we had initially
> identified the issue using gprof if I remember correctly.
> Not sure what patch you have in mind, but my opinion is that the Z and M
> members of pointObj need to remain disabled by default since they double
> the amount of memory required to store a pointObj (and a shape). Also my
> unverified guess is that in the case of bug 1244, the difference in
> processing time may have been caused by the fact that the compiler could
> not optimize access to the larger pointObj struct as efficiently as it
> could for the more compact struct.
> Daniel
> Umberto Nicoletti wrote:
> > I'm preparing to commit the GEOS patch this evening. I'll have a patch
> > for Z_M ready for review tomorrow.
> > Umberto
> > On 9/1/06, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> >> Initially pointObj's did have z and m members always but DM Solutions
> >> testing
> >> found a significant performance penalty for doing so. Perhaps that
> >> performance
> >> penalty can be addressed. However, when it comes to performance we
> >> should
> >> strive to keep that as high as possible. I think that trumps design
> >> consistency in
> >> a few instances.
> >> Steve
> >> >>> Tamas Szekeres <szekerest at GMAIL.COM> 8/31/2006 5:14:19 PM >>>
> >> Steve,
> >> Currently some members of some structs are also affected by the
> >> #defines (eg. shapeObj, pointObj) so if we want to accept this way for
> >> handling the issue every interface item should be generated regardless
> >> of the switches. For example shapeObj must always have a "void*
> >> geometry" and pointObj must always have z and m members.
> >> The second option would be to pass the preprocessor defines to the
> >> SWIG command line. (I could not get any reason why not to do it so
> >> far)
> >> So I think we should choose the right way according to the decision of
> >> the majority of the developers. The next IRC meeting would be a
> >> sufficient place to make the decision.
> >> Unfortunately I cannot take part on it at the proposed time. 2 hours
> >> later would be more suitable for me.
> >> I would have +0 on the first solution and +1 on the second one.
> >> Tamas
> >> 2006/8/31, Steve Lime <Steve.Lime at dnr.state.mn.us>:
> >> > I'm ok with the always having the geometry there and then hiding in
> >> any
> >> > case.
> >> > Regarding the defines with SWIG. I guess it boils down to whether or
> >> > not you
> >> > want:
> >> > 1) a consistent interface regardless of build environment, that
> >> is,
> >> > something like $shape->interects(...) always exists, but will throw
> >> an
> >> > error if the right supporting library isn't available
> >> > 2) an inconsistent interface that has different syntax depending
> >> on
> >> > build environment
> >> > Option 1 forces folks to practice good programming and actually
> >> check
> >> > returned values, while option 2 is far less subtle. You'll know
> >> right
> >> > away if something isn't available. Not sure which I prefer.
> >> > Steve
> >> > >>> Tamas Szekeres <szekerest at GMAIL.COM> 8/31/2006 6:49:48 AM >>>
> >> > Umberto,
> >> > At this point I cannot see considerable reason not to apply those
> >> > changes. But I am still sure that adding the defines to SWIG and the
> >> > mapscript C compilation ensures that the SWIG interface will be
> >> > generated correctly and no runtime problems will happen (dedicated
> >> to
> >> > this issue).
> >> > But again, I am +1 adding void* geometry to shapeObj regardless of
> >> the
> >> > USE_GEOS setting and hiding this member from the SWIG interface.
> >> > Tamas
> >> > 2006/8/31, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
> >> > > Tamas,
> >> > > I have reviewed all the .h files included in mapscript.i and I
> >> have
> >> > > found that there are only a few unsafe usages of defines (and they
> >> > > refer to the usual suspects, that is z/m members for points and
> >> > geos).
> >> > > In mapprimitive.h
> >> > > line 74 (Definitely UNSAFE!!)
> >> > > #ifdef USE_POINT_Z_M
> >> > > double z;
> >> > > double m;
> >> > > #endif
> >> > > line 100 (UNSAFE, but fixable):
> >> > > #ifdef USE_GEOS
> >> > > void *geometry;
> >> > > #endif
> >> > > Other suspicious usages could be in mapows.h, but at this time I
> >> am
> >> > > not sure whether they are actually posing a problem.
> >> > > I don't see an easy solution to the z/m defines, but I attach a
> >> > patch
> >> > > that removes the need for #ifdef USE_GEOS in mapprimitive.h. I
> >> have
> >> > > made a couple of tests and it seems ok to me, but I want your
> >> > valuable
> >> > > feedback and Steve's approval before I commit it.
> >> > > Umberto
