Missing elements in the SWIG interface documentation
Tamas Szekeres
szekerest at GMAIL.COM
Tue Sep 5 18:15:14 EDT 2006
Folks
This work seems greater than to be completed for beta3. I've added
descriptions for
imageObj.getBytes()
labelObj.autofollow
labelObj.encoding
layerObj.getProjection()
layerObj.whichShapes(rectObj) nextShape
mapObj.outputformatlist
mapObj.getNumSymbols()
markerCacheMemberObj class
styleObj.angle
styleObj.angleitem
styleObj.antialias
styleObj.maxcolor
styleObj.maxvalue
styleObj.maxwidth
styleObj.mincolor
styleObj.minwidth
styleObj.rangeitem
styleObj.sizeitem
styleObj.width
I would have the following members hidden:
labelCacheMemberObj.labelpath
layerObj.labelangleitemindex
layerObj.labelitemindex
layerObj.labelsizeitemindex
layerObj.plugin_library
layerObj.plugin_library_original (???)
layerObj.setProcessing(string) this method is deprecated ... should
use addProcessing()
mapObj.layerorder (superseded by getLayerDrawingOrder, setLayerDrawingOrder)
mapObj.saved_extent
styleObj.rangeitemindex
Since this list is not yet complete and I will not be able to commit
till 6 AM I will delay this work after beta3.
Tamas
2006/8/27, Tamas Szekeres <szekerest at gmail.com>:
> Developers,
> After comparing the SWIG interface and the corresponding documentation
> the following elements are missing and should be updated in the doc.
> I'm considering some of the interface elements are not to be exposed at all.
> 1. Missing interface elements
> 1.1 constants:
> int MAX_ERROR_LEN
> int MS_MAXCLASSES
> int MS_MAXSTYLES
> int MS_MAXLAYERS
> int MS_POSITIONS_LENGTH
> int MS_SHP_POINTZ
> int MS_SHP_ARCZ
> int MS_SHP_POLYGONZ
> int MS_SHP_MULTIPOINTZ
> int MS_GEOSERR
> int MS_RECTERR
> int MS_TIMEERR
> int MS_GMLERR
> int MS_SOSERR
> int MS_HASHSIZE
> int MAX_PARAMS
> 1.2 enums:
> Some of the constants are exposed as enumerations missing from the documentation
> 1.3 functions:
> public static void msConnPoolCloseUnreferenced();
> public static void msFreeImage(imageObj img);
> public static errorObj msGetErrorObj();
> public static string msGetErrorString(string delimiter);
> public static string msGetVersion();
> public static void msResetErrorList();
> mapscript.msSaveImage(mapObj, imageObj, String) : Int32
> mapscript.msSetup() : Int32
> 1.4 classes:
> DBFFieldType class
> DBFInfo class
> imageObj.getBytes()
> intarray.cast()
> intarray.frompointer(int*)
> intarray.getItem(int)
> intarray.setItem(int, int)
> labelCacheObj.labels
> labelObj.autofollow
> labelObj.encoding
> lineObj.point
> mapObj.layerorder
> mapObj.saved_extent
> outputFormatObj.formatoptions
> outputFormatObj.inmapfile
> outputFormatObj.numformatoptions
> outputFormatObj.refcount
> OWSRequest.contenttype
> queryMapObj class
> rectObj.fit(int,int)
> shapefileObj.isopen
> shapefileObj.lastshape
> shapefileObj.source
> shapefileObj.status
> shapefileObj.statusbounds
> shapefileObj.addPoint(pointObj)
> shapefileObj.getExtent(int, rectObj)
> shapefileObj.getPoint(int, pointObj)
> shapefileObj.getTransformed(mapObj, int, shapeObj)
> shapeObj.geometry
> shapeObj.line
> shapeObj.clone()
> styleObj.angle
> styleObj.angleitem
> styleObj.antialias
> styleObj.maxcolor
> styleObj.maxvalue
> styleObj.maxwidth
> styleObj.mincolor
> styleObj.minwidth
> styleObj.rangeitem
> styleObj.sizeitem
> styleObj.width
> symbolObj.style
> symbolObj.setImagepath(string)
> symbolSetObj.imagecachesize
> symbolSetObj.symbol
> webObj.browseformat
> webObj.legendformat
> 2. TODOs
> classObj.keyimage
> imageObj.size
> labelCacheMemberObj.featuresize
> labelCacheMemberObj.styles
> labelCacheObj.cachesize
> labelCacheObj.markercachesize
> labelObj.angle
> layerObj.footer
> layerObj.header
> layerObj.addFeature(shapeObj)
> layerObj.draw(mapObj, imageObj)
> layerObj.getNumFeatures
> mapObj.datapattern
> mapObj.maxsize
> mapObj.querymap
> mapObj.templatepattern
> mapObj.prepareQuery()
> OWSRequest.postrequest
> shapeObj.setBounds
> symbolObj.gap
> symbolObj.linecap
> symbolObj.linejoin
> symbolObj.linejoinmaxsize
> symbolObj.position
> symbolObj.sizex
> symbolObj.sizey
> symbolObj.transparent
> symbolObj.transparentcolor
> webObj.empty
> webObj.error
> webObj.log
> webObj.maxtemplate
> webObj.mintemplate
> webObj.queryformat
> Let us decide what to do with these elements. I think can document
> some of them but other volunteers should also be needed.
> \mapscript\doc\mapscript.txt should always be the most recent version.
> The class members should be placed into the documentation in alphabetical order.
> Tamas
