mapserver fastcgi memory leak
Ehud Shabtai eshabtai at GMAIL.COM
Tue Sep 12 17:16:32 EDT 2006
On 9/12/06, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> Ehud: Have you tried another version of Freetype or are you using the
> latest/greatest?
I'm using freetype-2.1.10.
The latest is 2.2.1. It seems that my system is not yet ready for an
upgrade to 2.2.x (2.2.x hides some undocumented interfaces and some of
my packages are not compatible with it).
The fact that the leak comes from freetype doesn't necessarily point
to a problem in freetype, it might be a problem in GD, or Mapserver.
I'm going to play with different map files and see if that makes any
change. I'm not confident that just any freetype string causes a leak,
and maybe I'll be able to better pin point on a specific feature in
the map file which causes the leak to show.
Ehud.
> >>> Ehud Shabtai <eshabtai at GMAIL.COM> 09/11/06 5:37 AM >>>
> Hi,
> I'm using Mapserver 4.8.4 as a fastcgi server along with postgis layers.
> Running a simple script which requests the same map over and over shows
> that
> mapserver's memory (RSS) is increasing by about 1MB for every 3
> requests.
> Mapserver starts with about 10mb and keeps increasing - I got to 200mb
> and
> killed it.
> Running shp2image with valgrind shows that the leak is in FreeType:
> ft_alloc (ftsystem.c)
> From mapserver's point of view the leak comes from msDrawTextGD. If I
> comment out all the gdImageStringFT calls I get no leak.
> Any ideas?
> Ehud Shabtai
> http://www.freemap.co.il/map/
Ehud Shabtai
