The bounding box request is different to the bbox received
Frank Warmerdam warmerdam at POBOX.COM
Tue Sep 19 14:22:02 EDT 2006
Bart van den Eijnden (OSGIS) wrote:
> Check this for more info:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1645
Bart,
I think 1645 only applies to non-WMS requests, since in WMS mode
the NON_SQUARE thing gets turned on automatically if needed.  In
any event, it seems that the request below is a square region with
a square request size so the pixels are already square.
>> Hi list,
>> I have a problem when I request a GetMap in mapserver 4.9 (FWtools
>> linux). I request a layer in tiff format with a specific bounding box
>> but the response doesn't have the same bounding box !!
>> For instance :
>> request=GetMap&version=1.1.1&width=64&height=64&layers=odcv05&styles=&srs=EPSG:4326&format=image/tiff&bbox=-0.3515625,38.583984375,-0.3076171875,38.6279296875
>> but if I do "gdalinfo" ... I obtain
>> minx= -0.3512192, miny = 38.5843277, max = -0.3079605  maxy = 38.6275864
>> Is mapserver operating correctly?
It does seem that there is some sort of problem.  If you can create a bug
report with data, mapfiles and any other supporting information required
linked from it, I can try to dig into what is happening.  Please assign
the bug report directly to me.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
