The bounding box request is different to the bbox received
José Vicente Higon
higon_jos at GVA.ES
Wed Sep 20 03:10:10 EDT 2006
Frank Warmerdam escribió:
> Bart van den Eijnden (OSGIS) wrote:
>> Check this for more info:
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1645
> Bart,
> I think 1645 only applies to non-WMS requests, since in WMS mode
> the NON_SQUARE thing gets turned on automatically if needed. In
> any event, it seems that the request below is a square region with
> a square request size so the pixels are already square.
>>> Hi list,
>>> I have a problem when I request a GetMap in mapserver 4.9 (FWtools
>>> linux). I request a layer in tiff format with a specific bounding box
>>> but the response doesn't have the same bounding box !!
>>> For instance :
>>> request=GetMap&version=1.1.1&width=64&height=64&layers=odcv05&styles=&srs=EPSG:4326&format=image/tiff&bbox=-0.3515625,38.583984375,-0.3076171875,38.6279296875
>>> but if I do "gdalinfo" ... I obtain
>>> minx= -0.3512192, miny = 38.5843277, max = -0.3079605 maxy =
>>> 38.6275864
>>> Is mapserver operating correctly?
> It does seem that there is some sort of problem. If you can create a bug
> report with data, mapfiles and any other supporting information required
> linked from it, I can try to dig into what is happening. Please assign
> the bug report directly to me.
> Best regards,
I just submit the bug. You can see in
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1916
Thanks.
José Vicente Higón
Grupo de desarrollo de gvSIG
Conselleria de Infraestructuras y Transporte
Generalitat Valenciana
Valencia - Spain
http://www.gvsig.gva.es
