RFC-24 Mapscript memory management: call for votes
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Mon Apr 2 09:14:46 EDT 2007
Tamas,
I am on the TSC. RFC1 only reflects the founding members I was added
later. You will see me listed in RFC23. It is not easy to find a current
list of TSC members, we should probably fix that.
-Steve W.
Tamas Szekeres wrote:
> Umberto,
> According to #6 only members of the Technical Steering Committee's
> votes will be counted so you should wait for another +1 from a TSC
> member before announcing the results and committing the changes,
> Best regards,
> Tamas
> 2007/4/2, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
>> Currently the voting request has been on line for over a week and it
>> is going as follows:
>> +2 (me, Stephen Woodbridge)
>> +0 Frank Warmerdam
>> I have reread RFC1, and according to item 7 I can consider it approved
>> even though I'd hoped to see some more votes.
>> Anyway, I'll update the rfc with a compatibility section to comply
>> with Stephen's requirements and then I'll start committing changes. I
>> should be done by next week (sunday 14) because of Easter and some
>> other projects' deadlines in this week.
>> Thanks to all,
>> Umberto
>> On 3/24/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
>> > I took some time to update the RFC text at:
>> > http://mapserver.gis.umn.edu/development/rfc/ms-rfc-24
