server side SLD support
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Apr 4 14:31:34 EDT 2007
Hi All,
Few months ago there was a discussion on this list about
options/impacts on enabling Mapserver map file to use an SLD file (local
or http) as a styling mechanism instead of using classes on a layer.
The functionality is simple in principle : something like a keyword
(STYLEDLAYERDESCRIPTOR) on the layer with a link to the sld file would
allow Mapserver to create classes on this layer (this would be
equivalent to the applySLD functionality available in Mapscript)
As a reminder here is a link to that discussion :
http://www.nabble.com/server-side-SLD-support-tf2550774.html#a7109496
At the end of this discussion, I think the main problem was deciding
how to handle classes generated by the SLD tag when saving a map file
through Mapscript : do we save the generated classes or do we save the
SLD tag ? Pros and cons are :
1. do not include SLD when saving the map file (the generated classes
would be saved normally)
Pros:
- implementation is straight forward
- there are no side effects for existing applications and frameworks
Cons:
- lose the original structure of the map file
2. include SLD when saving the map file (do not save the generated
classes)
Pros:
- maintain original structure of map file
Cons:
- what to do with classes altered through mapscript
Here are some compromising points that were mentioned in this thread:
- never mix classes and sld (either one or the other)
- saving generated classes or the sld link could be an optional
setting at the layer level (default could be saving the sld)
- mapscript would not be exposed to set the sld (only get that value)
since the applysld function can be used to generate classes on the layer
- document the short comings for tools who manipulate layer classes
As far as I understand, there is no solutions that does it all and if
we want to go ahead on this, it has to be a compromise with a defined
behavior. Any more comments on this issue ?
Thnaks
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
