build error
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Wed Apr 18 05:24:55 EDT 2007
After applying the following two patches mapserver *compiles* in this
configuration.
./configure --with-threads --without-pdf --without-tiff --with-gdal
--with-proj --with-geos --with-ming --with-ogr --with-wms --with-wcs
--with-sos -with-agg --with-wmsclient --with-wfsclient --with-eppl
I am on Ubuntu Feisty.
I cannot apply the patches today, since I am at a customer site
without cvs access.
Please report status so I can commit the changes asap.
Umberto
On 4/18/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> I'm working on fixing it...
> I'll make a patch available later today.
> Umberto
> On 4/17/07, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
> > on FC6, using latest CVS, using:
> > $ ./configure --enable-debug --with-freetype=/usr/local/bin/freetype-config --with-zlib=/usr/local/ --with-png=/usr/local/ --w
> > ith-jpeg=/usr/local/ --with-gd=/usr/local --with-pdf=/usr/local --with-eppl --with-proj=/usr/local --with-ogr=/usr/local/bin
> > /gdal-config --with-gdal=/usr/local/bin/gdal-config --without-tiff --with-postgis=/usr/local/pgsql/bin/pg_config --with-wfs
> > --with-wcs --with-wmsclient --with-wfsclient --with-curl-config=/usr/local/bin/curl-config --with-xpm=/usr/local --with-php=
> > /usr/local/src/php/php-5.2.1 --with-ming=/usr/local --with-sos --with-geos=/usr/local/bin/geos-config --with-agg=/usr/local/
> > src/agg/agg-2.5/
> > mapswf.c: In function âmsDrawMarkerSymbolSWFâ:
> > mapswf.c:1326: error: expected â)â before â;â token
> > mapswf.c:1539: warning: assignment from incompatible pointer type
> > mapswf.c:1539: error: expected â;â before â}â token
> > mapswf.c:1266: warning: unused variable âfcâ
> > I fixed (but did not commit) this in mapswf.c, but then I got errors in mapogcfilter.c. Checking HEAD shows numerous updates related to RFC 24. As this looks like a huge bunch of changes, I did not touch anything, for maybe Umberto to check first.
> > ..Tom
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20070418/2ca72d7f/rfc24-pathKralidis-mapogcsld.bin
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20070418/2ca72d7f/rfc24-pathKralidis-mapswf.bin
