build error
Kralidis,Tom [Burlington] Tom.Kralidis at EC.GC.CA
Wed Apr 18 10:14:05 EDT 2007
Thx.  The patches seemed to work, but now
$ patch -p0 < rfc24-pathKralidis-mapogcsld.patch
patching file mapogcsld.c
$ patch -p0 < rfc24-pathKralidis-mapswf.patch
patching file mapswf.c
$ make
mapogcfilter.o
mapogcfilter.c: In function âFLTGetQueryResultsForNodeâ:
mapogcfilter.c:375: warning: assignment from incompatible pointer type
mapogcfilter.c:381: error: expected identifier before â)â token
mapogcfilter.c:559: error: expected â;â before â}â token
mapogcfilter.c:610: error: invalid storage class for function âaddResultâ
mapogcfilter.c: In function âFLTAddToLayerResultCacheâ:
mapogcfilter.c:659: warning: assignment from incompatible pointer type
mapogcfilter.c: In function âFLTArraysNotâ:
mapogcfilter.c:761: warning: assignment from incompatible pointer type
mapogcfilter.c: In function âFLTApplySimpleSQLFilterâ:
mapogcfilter.c:998: warning: assignment from incompatible pointer type
mapogcfilter.c:1047: error: expected identifier before â)â token
mapogcfilter.c:1070: error: expected â;â before â}â token
mapogcfilter.c:996: warning: unused variable âpszBufferâ
mapogcfilter.c:994: warning: unused variable âmsErrâ
mapogcfilter.c:988: warning: unused variable âszExpressionâ
mapogcfilter.c: In function âFLTApplyFilterToLayerâ:
mapogcfilter.c:1151: warning: initialization from incompatible pointer type
mapogcfilter.c: In function âFLTLayerApplyPlainFilterToLayerâ:
mapogcfilter.c:1196: warning: assignment from incompatible pointer type
mapogcfilter.c:3624: error: expected declaration or statement at end of input
mapogcfilter.c:348: warning: unused variable âdfCurrentToleranceâ
mapogcfilter.c:344: warning: unused variable âpanResultsâ
mapogcfilter.c:343: warning: unused variable âsProjTmpâ
mapogcfilter.c:342: warning: unused variable ânTokensâ
mapogcfilter.c:341: warning: unused variable âtokensâ
mapogcfilter.c:336: warning: unused variable âiâ
mapogcfilter.c:336: warning: unused variable ânEpsgTmpâ
make: *** [mapogcfilter.o] Error 1
..so then I made changes to mapogcfilter.c:
$ cvs diff mapogcfilter.c
Index: mapogcfilter.c
RCS file: /data2/cvsroot/mapserver/mapogcfilter.c,v
retrieving revision 1.71
diff -r1.71 mapogcfilter.c
381c381
<         initClass(&(lp->class[0]->);
>         initClass(&(lp->class[0]));
408c408
<                     initClass(&(lp->class[1]->);
>                     initClass(&(lp->class[1]));
1047c1047
...and then receive the following error:
php_mapscript.c: In function âphp3_ms_map_getAllLayerNamesâ:
php_mapscript.c:3903: error: request for member ânameâ in something not a structure or union
make[1]: *** [php_mapscript.o] Error 1
make[1]: Leaving directory `/usr/local/src/mapserver/cvs/mapserver/mapscript/php3'
$ make
php_mapscript.c: In function "php3_ms_map_getAllLayerNames":
Again, I have not committed anything as this looks like a bunch of wholesale changes.
..Tom
	-----Original Message-----
	From: UMN MapServer Developers List on behalf of Umberto Nicoletti
	Sent: Wed 18-Apr-07 05:24
	To: MAPSERVER-DEV at LISTS.UMN.EDU
	Cc:
	Subject: Re: [UMN_MAPSERVER-DEV] build error
	After applying the following two patches mapserver *compiles* in this
	configuration.
	./configure --with-threads --without-pdf --without-tiff --with-gdal
	--with-proj --with-geos --with-ming --with-ogr --with-wms --with-wcs
	--with-sos -with-agg --with-wmsclient --with-wfsclient --with-eppl
	I am on Ubuntu Feisty.
	I cannot apply the patches today, since I am at a customer site
	without cvs access.
	Please report status so I can commit the changes asap.
	Umberto
	On 4/18/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
	> I'm working on fixing it...
	> I'll make a patch available later today.
	> Umberto
	> On 4/17/07, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
	> > on FC6, using latest CVS, using:
	> > $ ./configure --enable-debug --with-freetype=/usr/local/bin/freetype-config --with-zlib=/usr/local/ --with-png=/usr/local/ --w
	> > ith-jpeg=/usr/local/ --with-gd=/usr/local --with-pdf=/usr/local --with-eppl --with-proj=/usr/local --with-ogr=/usr/local/bin
	> > /gdal-config --with-gdal=/usr/local/bin/gdal-config --without-tiff --with-postgis=/usr/local/pgsql/bin/pg_config --with-wfs
	> > --with-wcs --with-wmsclient --with-wfsclient --with-curl-config=/usr/local/bin/curl-config --with-xpm=/usr/local --with-php=
	> > /usr/local/src/php/php-5.2.1 --with-ming=/usr/local --with-sos --with-geos=/usr/local/bin/geos-config --with-agg=/usr/local/
	> > src/agg/agg-2.5/
	> > mapswf.c: In function âmsDrawMarkerSymbolSWFâ:
	> > mapswf.c:1326: error: expected â)â before â;â token
	> > mapswf.c:1539: warning: assignment from incompatible pointer type
	> > mapswf.c:1539: error: expected â;â before â}â token
	> > mapswf.c:1266: warning: unused variable âfcâ
	> > I fixed (but did not commit) this in mapswf.c, but then I got errors in mapogcfilter.c.  Checking HEAD shows numerous updates related to RFC 24.  As this looks like a huge bunch of changes, I did not touch anything, for maybe Umberto to check first.
	> > ..Tom
