[UMN_MAPSERVER-DEV] C# layerObj.draw &&
layerObj.drawLegend
Tamas Szekeres
szekerest at GMAIL.COM
Mon Apr 23 05:25:27 EDT 2007
Currently there's no separate function for drawing a legend item for one
layer. However you can temporarily disable including the other layers by
setting their layerObj.status to MS_OFF or layerObj.type to
MS_LAYER_TYPE.MS_LAYER_QUERY.
Best regards,
Tamas
2007/4/23, Jean Michel PIERRET <jmp at geosys.com>:
> Hi,
> 1)
> I guess you should either disable the labelcache for this layer (
> layerObj.labelcache = mapscript.MS_OFF ) or call layerObj.drawlabelcacheexplicitly right after drawing the shapes.
> It's ok for the label with (layerObj.labelcache = mapscript.MS_OFF),
> drawlabelcache does not exist on layerObj but on mapObj.
> lobj.labelcache = mapscript.MS_OFF;
> lobj.draw(_lobj.map, iobj);
> or
> lobj.map.drawlabelcache(iobj);
> 2)
> Here is a function extracted from my previous project for drawing the
> legend image, hopefully it applies to your intents fairly enough.
> private Image CreateLegendImage(layerObj layer, int classindex, int width,
> int height, int keysizex, int keysizey)
> using (classObj def_class = new classObj(null)) // for drawing
> legend images
> using (imageObj image = def_class.createLegendIcon(map,
> layer, width, height))
> classObj layerclass = layer.getClass(classindex);
> layerclass.drawLegendIcon(layer.map, layer, keysizex,
> keysizey, image,
> (width - keysizex) / 2, (height - keysizey) / 2);
> byte[] img = image.getBytes();
> using (MemoryStream ms = new MemoryStream(img))
> return Image.FromStream(ms);
> Your function work but for one class only and without label, I'm looking
> for a function which give me the same result of mapObj.drawLegend with
> only on layer activate.
> Thanks,
> Regards.
> *Jean-michel PIERRET <jmp at geosys.com> - Poste 376*
> *Tel : +33 (0)5 62 47 80 76*
> *Mail* : jmp at geosys.com
> *GEOSYS SA*
> -----Message d'origine-----
> *De :* UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
> *De la part de* Tamas Szekeres
> *Envoyé :* vendredi 20 avril 2007 21:15
> *À :* MAPSERVER-DEV at LISTS.UMN.EDU
> *Objet :* Re: [UMN_MAPSERVER-DEV] C# layerObj.draw && layerObj.drawLegend
> 2007/4/20, Jean Michel PIERRET <jmp at geosys.com>:
> Hi,
> I'm using mapserver with c# bindings and i have two questions.
> 1)
> layerObj lobj = null;
> imageObj iobj = null;
> iobj = lobj.map.prepareImage();
> In the drawn image, the labels don't appear, whereas with the method
> mapObj.draw they are there. It is normal ?.
> 2)
> Exist there a method to draw legend for one layer only and not for all the
> map.
> legend images
> keysizey, image,
> Best regards,
> Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20070423/be4142df/attachment.html
