Drawing Raster Query Results
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Mon Apr 23 18:08:29 EDT 2007
Result sets can span many layers and data types so it can get messy very quickly.
Steve
>>> On 4/23/2007 at 4:48 PM, in message
<f3b73b7d0704231448j82fd0fwd93ad441737ec146 at mail.gmail.com>, Tamas Szekeres
<szekerest at GMAIL.COM> wrote:
> Frank,
> I'm personally not too pleased with the current resultcache approach
> as the primary solution of storing a results of a query. Why don't we
> add the results to a predefinied inline layer? This approach would
> provide all of the facilities for styling the results as we have
> normally for a layer. The user could additionally swich on/off this
> layer or eventally start a subsequent query based on this previous
> query in another layer for example.
> Threating the raster layers as point layers is a bit quicky for me.
> Best regards,
> Tamas
> 2007/4/23, Frank Warmerdam <warmerdam at pobox.com>:
>> Folks,
>> A couple years ago I implemented support for "query" against a raster layer.
>> Such queries essentially return a list of point features, generally one for
>> each pixel that satisfies the query criteria.
>> Recently a user has run into problems when they try to draw a map of the
>> query result. This isn't something I've ever tried before, and to be
> honest,
>> I'm a bit vague on how queries are normally used in MapServer. I assumed
> they
>> were mostly used for populating tabular results which does work fine.
>> The drawing a query layer for a map result doesn't work properly, as
> documented
>> in:
>> http://trac.osgeo.org/mapserver/ticket/2069
>> The question, to my mind, is whether it makes sense to try and draw point
>> features from a raster query result on a map, and if we did so how do we
>> differentiate styling used for the raster from styling used for the query
>> results which are a very different sort of data.
>> I'm tempted to modify msDrawQueryLayer() to do nothing raster layers, but to
>> issue a debug message indicating that the layer is being skipped since
> drawing
>> raster query results is considered an unclear request.
>> If anyone has an opinion contrary to my idea to disallow this, please let me
>> know on this list, or via the ticket.
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | President OSGeo, http://osgeo.org
