Motion: Migrate to SVN was (Re: [UMN_MAPSERVER-DEV] Mapserver
buildbot and the SVN transition)
Howard Butler
hobu.inc at GMAIL.COM
Wed Apr 25 13:33:15 EDT 2007
I will be using cvs2svn, which dumps a default layout like:
./tags
./branches
./trunk
All of the history will be preserved as part of the migration (I
wouldn't migrate if we couldn't).
Also, re: Note2.
I have incremental dumps that happen on a 3 hour cycle that get put
in http://svn.osgeo.org/dumps The intent here is that you do a wget
--mirror and after the first big flush of data, the bandwidth costs
to keep a mirror in the future is tiny. The files are gzipped and
named in such a way that they can be cat'ed together to make a svn
dump file that can be used to recreate the repository.
Howard
On Apr 25, 2007, at 9:50 AM, Daniel Morissette wrote:
> +1 with the added caveat that all history, including CVS tags and
> branches is maintained during the conversion.
> Daniel
> Note1: the mapserver CVS repository contains the following folders.
> I presume that they will all be transported?
> jbox
> mapserver
> mapserver_demos
> mapserver_docs
> mapserver_nightly
> msautotest
> Note2: The mapserver CVS repository is replicated on maptools every
> morning at 3am, so if Steve cannot provide a tarball then I can get
> you one (or Frank can if I'm not available since he has access to
> the server).
> Frank Warmerdam wrote:
>> Howard Butler wrote:
>>> I move that we migrate to Subversion this weekend. I can take
>>> care of the legwork of migrating and would need Steve to provide
>>> a tarball to do so.
>> +1
>> (with the caveat that it occurs as soon as Howard and Steve can make
>> arrangements, and that notice on the transition be send to
>> mapserver-dev)
>> Best regards,
> Daniel Morissette
> http://www.mapgears.com/
