Build with debug
Tamas Szekeres
szekerest at GMAIL.COM
Thu Apr 26 13:21:47 EDT 2007
Johan,
You might have to compile with ENABLE_STDERR_DEBUG and use "DEBUG ON"
in your map configuration.
Verbose output is generated and sent to the standard error output (STDERR).
Best regards,
Tamas
2007/4/26, Hallgren Johan E <jhhal at wmdata.com>:
> Hello
> I tries to build MapServer so I can see msDebug()-output. I expect to see
> the output in the VS-output window, or in the console running the program
> but I don't. Do I have to change some compiler directives that I have
> missed?
> /Johan
> ___________________________________
> Johan Hallgren
> WM-data a LogicaCMG company
> Pelle Bergs backe 3
> Box 1938, 791 19 Falun
> Tel: 023-547 46 (int: +46-2354746)
> Mobil: 070-588 44 28 (int: +46-705884428)
> johan.e.hallgren at wmdata.com
> http://www.wmdata.se
