Build with debug
    Tamas Szekeres
    szekerest at GMAIL.COM
    Fri Apr 27 11:09:03 EDT 2007
Johan,
As far as I can see the only way to support this requirement is to
redirect the stderr output to the Windows debug console using the
OutputDebugString API.
Currently, Mapserver does not support this method. So if you find this
feature useful you might submit a ticket on it. I think it's not so
difficult to implement this kind of solution if needed.
Best regards,
Tamas
2007/4/27, Hallgren Johan E <jhhal at wmdata.com>:
> Hello Tamas
> These are the settins I use, do you mean that this it should be correct? I
> have DEBUG ON on both root tag and on the specifc layer. Could the output be
> somewhere where I dont't see it? I use Mapscript in Visual studio, and I
> expected to see the ouput at the Debug/output window.
> # Optimized, with using MSVCRT.
> OPTFLAGS = /nologo /Ox /MD $(WARNING_LEVEL) $(DEBUG) /EHsc
> # Uncomment the following to link mapserv.exe with a dll. In almost
> # all cases you will want to do this.
> DLLBUILD = 1
> # Set the Warning level for the compiler (defaults to W1)
> WARNING_LEVEL=/W3
> # Debugging Options
> ENABLE_STDERR_DEBUG=-DENABLE_STDERR_DEBUG
> # Set the linker debug option
> # LDEBUG=/debug
> # DEBUG Build flags
> # Set the DEBUG flag if you wish to make a debug build
> # DEBUG=/DDEBUG
> Johan
> ___________________________________
> Johan Hallgren
> WM-data
> Pelle Bergs backe 3
> Box 1938, 791 19 Falun
> Tel (och mobil): 023-547 46 (int: +46-2354746)johan.e.hallgren at wmdata.com
> http://www.wmdata.se
>  Från: Tamas Szekeres [mailto:szekerest at gmail.com]
> Skickat: to 2007-04-26 19:21
> Till: Hallgren Johan E
> Kopia: MAPSERVER-DEV at lists.umn.edu
> Ämne: Re: Build with debug
> Johan,
> You might have to compile with ENABLE_STDERR_DEBUG and use "DEBUG ON"
> in your map configuration.
> Verbose output is generated and sent to the standard error output (STDERR).
> Best regards,
> Tamas
> 2007/4/26, Hallgren Johan E <jhhal at wmdata.com>:
> > Hello
> > I tries to build MapServer so I can see msDebug()-output. I expect to see
> > the output in the VS-output window, or in the console running the program
> > but I don't. Do I have to change some compiler directives that I have
> > missed?
> > /Johan
> > Johan Hallgren
> > WM-data a LogicaCMG company
> > Pelle Bergs backe 3
> > Tel: 023-547 46 (int: +46-2354746)
> > Mobil: 070-588 44 28 (int: +46-705884428)
