Loading a mapfile from a string...
Steve Lime Steve.Lime at DNR.STATE.MN.US
Fri Apr 27 13:09:42 EDT 2007
Yes, that's the lexer version issue. You can either upgrade the lexer used on windows, or comment out
that one line in mapfile.c. What tool is used to build maplexer.l on windows?
Steve
>>> On 4/27/2007 at 10:41 AM, in message
<f3b73b7d0704270841j48d0d4fex4275054762be191e at mail.gmail.com>, "Tamas Szekeres"
<szekerest at gmail.com> wrote:
> Steve,
> When building the CVS-HEAD on Windows I got:
>  Creating library mapserver_i.lib and object mapserver_i.exp
> mapfile.obj : error LNK2019: unresolved external symbol
> _msyylex_destroy referenced in function _msLoadMapFromString
> libmap.dll : fatal error LNK1120: 1 unresolved externals
> NMAKE : fatal error U1077: 'link' : return code '0x460'
> Stop.
> Is this problem related to this change?
> Best regards,
> Tamas
> 2007/4/27, Steve Lime <Steve.Lime at dnr.state.mn.us>:
>> Only one comment (and positive at that) so... this has been commited. One
> caveat is that to avoid leaking memory yylex_destroy is being used to clean
> things up. Apparently this is available in newer versions of flex. May
> actually be there in old versions but only if a reentrant scanner is being
> built. Presents a small problem. We can control the distributions by using a
> newish version of flex when building things for users. Requiring developers
> to use version x.x.x (I'm at 2.5.31) doesn't seem to big a hardship.
> Thoughts?
>> Steve
>> >>> Steve Lime <Steve.Lime at DNR.STATE.MN.US> 04/17/07 11:28 PM >>>
>> Hi Folks: I've been screwing around with getting mapserver to ingest a
> mapfile stored in a string buffer rather than a file. In theory you could
> build up a configuration from text snippets or database output rather than
> manipulating objects directly. The code could almost do this in the past but
> needed some reorganization to re-use as much as possible. The result is a new
> function called msLoadMapFromString. I took the opportunity to fix some
> naming wierdness in mapfile.c and to clean up lexer initialization a bit. In
> otherwords I'm sitting on a fair number of minor changes to mapfile.c and
> maplexer.l (with a few other small edits elsewhere). Is this a big enough
> deal to warrant a RFC or can I just commit?
>> Steve
>> BTW A sample perl snippet might look like (mapscript integration isn't part
> of these changes other than exposing the function):
>> $buffer = "MAP ... END";
>> $map = $mapscript::msLoadMapFromString($buffer, undef); # takes the buffer
> and an optional directory (location of symbols...)
